Manifold bolts, how tight?
   / Manifold bolts, how tight? #1
dapper
S.W. Ohio
NH TN-65, Ford/NH 3430, Ford/NH 3930, Kubota zd21
Anyone know how tight to torque the exhaust manifold bolts on a NH3430? I am changing out the vertical exhaust, and will be replacing the manifold, and can not find this info.
Thanks for your help
Dap.
   / Manifold bolts, how tight? #2
Use the standard torque value for the diameter, pitch, and hardness of the bolts. Should be about 30 ft/lbs for 3/8-16 grade 5.
Mr. B,
As always your "THE MAN". Thanks for the answer on torque. And for being on line. Your an asset to all. I know all appreciate your wisdom as much as I.
Thanks again. :)
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
7021 (A50322)
7021 (A50322)
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
