Manifold bolts, how tight?
   / Manifold bolts, how tight? #1
dapper
S.W. Ohio
NH TN-65, Ford/NH 3430, Ford/NH 3930, Kubota zd21
Anyone know how tight to torque the exhaust manifold bolts on a NH3430? I am changing out the vertical exhaust, and will be replacing the manifold, and can not find this info.
Thanks for your help
Dap.
   / Manifold bolts, how tight? #2
Use the standard torque value for the diameter, pitch, and hardness of the bolts. Should be about 30 ft/lbs for 3/8-16 grade 5.
Mr. B,
As always your "THE MAN". Thanks for the answer on torque. And for being on line. Your an asset to all. I know all appreciate your wisdom as much as I.
Thanks again. :)
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
