Man I hope some of you clutch guys can help me
   / Man I hope some of you clutch guys can help me #1
Kosmo
NE Pa
Ford/NH 1715
Hi all,
So I'm putting the clutch job on my 1715 compact back together, and I go to install the thrust bearing and I can't remember for sure which face of the bearing goes toward the clutch. The diagram in the manual suggests that my memory is wrong. Does anyone know if the smooth face of the bearing faces the clutch? I could have sworn that this was the case until I looked at that diagram in the manual.
   / Man I hope some of you clutch guys can help me #2
There should be a flat face that compresses the fingers on the pressure plate. If you hold from the inside (as if mounted) then look at the bearing and how it spins, should be fairly clear which area contacts the fingers.
Yeah, That flat face was the way I thought it should be but the diagram in the manual confused me. Thanks a bunch!!
Jones, just being **** and checking with a picture.
The new bearing is installed to the hub correctly as I see it on the right. The old bearing on the left shows the backside. Is this correct? Thanks for your input again. Also, do you know if the hub gets any kind of grease where it slides onto the hub support shaft. It appears that there was old grease on that shaft but I would expect, during assembly it, should be very minimal due to proximity to the clutch. NH manual says nothing about lubrication during assembly. Thanks again.
   / Man I hope some of you clutch guys can help me #5
The repair manual that I have states "Lightly lubricate the hub splines of the transmission input shaft using a high temperature lubricant." The bearing install looks correct.
Thanks billybob!!
   / Man I hope some of you clutch guys can help me #7
Yes that is mounted correct.
2012 Ram 4500 Chassis Vesralift 29ft Bucket Truck (A50323)
2012 Ram 4500...
2017 Nissan Titan Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
Woods RM660 3pt. Finish Mower (A50774)
Woods RM660 3pt...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
