Making Trails...Which attachment?
/ Making Trails...Which attachment? #1
jay_ch28
Connecticut
New Holland TC40D
Hello,
I'll start by telling you a little about my equipment. I have a TC40D with a toothbar and a boxblade. I'm a decent operator with about 350 hrs on my machine.
I build a motocross track and want to expand it next year. The plan is to make trails through the woods. My woods are mostly Pine. This winter I've got a logging company coming in to "manage" the forest. Once they are done I'm going to make a trail loop through the woods and back to my track. I don't want to dig into the soil. I just want to get past all of the material on top (leaves/needles/etc...). I was wondering if a Landscaping rack would be good for this. Or will I be better off using my Box Blade? Stumps are not a problem.
/ Making Trails...Which attachment? #2
I've been clearing paths thru the trees by the pond with the neighbor and I used my box blade and FEL to clear the leaves and stuff very quickly and then roto cut the little stuff i couldn't get up by lightly draging with the box blade. Since you will be going much longer distance this might not be fast enough for ya but it supprised me how fast I was able to push and drag stuff out to be burned or piled in a compost heap (aka ditch)
/ Making Trails...Which attachment? #3
I would think the rake would work better than the box blade if you don't want to disturb the soil. I've created several trails with just my chain saw and brush hog, then cutting out the small underground stumps with an ax. Of course, I've got mostly oaks and hickory and very few pine trees. Oh yea... and millions of grapevines and sassafras trees.
/ Making Trails...Which attachment? #4
Perhaps try the toothbar and box blade to see if they can produce the results you want. I would think they will work.
Egon
/ Making Trails...Which attachment? #5
I have found that my boxblade is a great tool in the woods. i use mine alot keeping trails on our hunting leases in good shape. i also use it to make new trails and it is great.
/ Making Trails...Which attachment? #6
I've done the same thing. Problem is,our soil tends to turn into silty mush if it doesnt have something to hold it together. Especially this time of year when it seems to rain every 3 days from Sept to July. I used a bush hog and went around as many trees as possible. Little trees got stumped up. This allowed the ground to maintain its integrity (less rutting) and made for a funner route. After awhile the pine needles cover and kill the plants I was having to bushog. Originally I boxbladed the front part of the trail but it seemed to never recover and even needles couldnt stop the erosion.
I guess it depends on your soil , weather, and or topography.
Thanks for all of your replies. I'm going to try it with the equipment I have and see how it turns out before purchasing some new toys.
/ Making Trails...Which attachment? #8
You may wish to layout the trails prior to the logging operation. Otherwise, they'll make their own. If you get some form of trails in first, they'll likely use what you put down as much as practical and probably make them even wider than you might.
that's what I did. I made the roughed out trail, by just draggin the teeth of the box blade and pulling out the brush and smaller trees.
For the final product I want to have only dirt on the trails, nothing else. No leaves, pine needles, brush, or anything else. However I want to remove as little dirt as possible. I didn't know how well a landscaping rake would work for this purpose having never used one. I think I will just have to wait to see what it looks like in the spring after the loggers finish up. They started cutting last tuesday, but not in the area I'm talking about. I guess they will be cutting for 4 weeks if the weather cooperates and the ground stays frozen. Although they are claiming it will be 53 degrees on thursday and above freezing for the following week, so who knows.
Has anyone had thier forest "Selective Harvested". I'm wondering what the roads will look like when they are completed. Just before the ground froze it was pretty wet back there. I've seen some logging roads that had deep ruts from the skidders and forwarders. I'm hoping this won't be the case here if it stays cold.
/ Making Trails...Which attachment? #10
Regarding Select Harvest methods, I have seen many different variations of this procedure. The most important questions is: What does your timber contract allow? Some contractors will tell you what you want to hear all day long, but what is in writing, is what matters at the end of the day.
The results from select harvest can be quite different than what some expect.
Any logging operation involving heavy equipment can alter the land - If it were me, I would keep the loggers out if the ground is too wet. Then again my property is mountainous, and erosion is a concern for me, and the loggers in your area may alsio be more environmentally conscious.
well I live on a hill and valley. The hill section they logged last year and it looks good. I have cord wood guy in there know taking what the lumber guys lefte behind.
The Lumber guys are supposed to be coming back shortly to finish the job in the valley where it is typically wet. I have everything marked that they are going to cut. If they cut trees that are not marked I'll be able to tell because the stump where the markings are must still be showing after the tree is cut. So far they have been very good to deal with.
Here's hoping it stays that way.
/ Making Trails...Which attachment? #12
I was wondering if one of the tow-behind wheel rakes sold by Northern Tools would remove leaves and pine needles. Anyone tried it?
/ Making Trails...Which attachment? #13
</font><font color="blue" class="small">( that's what I did. I made the roughed out trail, by just draggin the teeth of the box blade and pulling out the brush and smaller trees. )</font>
Hey jay i am not trying to be a smart --- but just thought i would say be careful when you drag those scarifiers.
I had mine all the way down and the top link shortened all the way and was just a getting it. i hit a root and the tractor STOPPED pretty quick! i ended up bending one lift link attachment pin on my box blade and one scarifier.
and hey it jarred me pretty good to.
just thought i would share that so if it happens to you, you can say "hey i heard of this happening!" /forums/images/graemlins/grin.gif
2014 Timpte Hopper Bottom (A63118)
2014 Timpte Hopper...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2025 IR IRET13 ELECTRIC TRICYCLE (A62130)
2025 IR IRET13...
2020 CATERPILLAR 306CR EXCAVATOR (A62129)
2020 CATERPILLAR...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2023 Stearling Trailer (A60352)
2023 Stearling...
