Snow Making Snow plow Blade Larger on BX2230?
   / Making Snow plow Blade Larger on BX2230? #1
redharley
central, Pa
BX2230
Anyone out there add any extra size to there Kubota snow blades?If so how much?Any ploblems?I have a BX2230 with the 54" realy don't need power angle but some extra width would be nice, any info or Pic's would be helpful.Thanks Red
   / Making Snow plow Blade Larger on BX2230? #2
I added a wear strip to my rear blade of high density plastic. I seem to recall that someone increased the width of a blade by using wider sheets of the plastic and heat forming it in order to fit the contours of the blade. I can't seem to to find the post though.
Anyone remember ?
   / Making Snow plow Blade Larger on BX2230? #3
On my B 2710 I widened the blade from 6' to 8'.
Through bolted a 3' piece of 2x2 angle iron to the cutting blade on each side of the blade. Then took some 1/2 thick rubber conveyor belting an bolted it to the angle iron and the plow blade.
After 3 yrs it is still working fine.
The increased width makes a tremendous difference.
Sry but I haven't figured out how to post a pic.
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56435)
LIKE NEW 2023...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
