Snow Making Snow plow Blade Larger on BX2230?
   / Making Snow plow Blade Larger on BX2230? #1
redharley
central, Pa
BX2230
Anyone out there add any extra size to there Kubota snow blades?If so how much?Any ploblems?I have a BX2230 with the 54" realy don't need power angle but some extra width would be nice, any info or Pic's would be helpful.Thanks Red
   / Making Snow plow Blade Larger on BX2230? #2
I added a wear strip to my rear blade of high density plastic. I seem to recall that someone increased the width of a blade by using wider sheets of the plastic and heat forming it in order to fit the contours of the blade. I can't seem to to find the post though.
Anyone remember ?
   / Making Snow plow Blade Larger on BX2230? #3
On my B 2710 I widened the blade from 6' to 8'.
Through bolted a 3' piece of 2x2 angle iron to the cutting blade on each side of the blade. Then took some 1/2 thick rubber conveyor belting an bolted it to the angle iron and the plow blade.
After 3 yrs it is still working fine.
The increased width makes a tremendous difference.
Sry but I haven't figured out how to post a pic.
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
Gehl Mix-All Mill (A50515)
Gehl Mix-All Mill...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
