Making quick attach pallet forks from scrap around the shop
   / Making quick attach pallet forks from scrap around the shop #1
RogueFab
Sandy, Oregon
New Holland T2420
I know you all will hate this... They are going to be fixed width! I want them rigid, and the pallets I handle have a small range of widths. These are going to be simple, and rated for a ton (total) with a safety factor of 2.0.
Starting with the only purchased part/material: Quick Attach plate. 5/16 and 3/8 A50 steel. Less than $100 delivered, and saves a day of fab work since we don't have tools to mess with plate.
Next we bent up some 1 inch .095 wall square stock for a material safety rack. It won't stop a one ton hay bale, but I don't do hay work ;)
   / Making quick attach pallet forks from scrap around the shop #2
Looks like you have a good start on your project. A minor suggestion if you will (from a non-expert novice) so take it for what it's worth. I would build your frame with the outer sections running down the outside of your quick attach plate. It would provide a lot more structural rigidity. I modified your photo and added some red lines to indicate where I am referring. Keep us posted on how this goes as I am considering either the purchase or the fabrication of a similar setup.
Mike
I have had them done for a while now. I have moved plenty of stuff (compressor, logs, pallets of material, etc). Love them.
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
Case SV185 Compact Wheel Loader Skid Steer (A51691)
Case SV185 Compact...
Valvoline Brake Fluid (A53117)
Valvoline Brake...
