Making Middlebuster go deeper
/ Making Middlebuster go deeper #1
bcarwell
Austin, Texas
Kabota 7500DT
I have a Kubota 7500 and a new Middlebuster from Tractor Supply. Used it for the first time today and the deepest I could make it dig was about 8 inches with the 3PH lowered all the way.
Could somebody tell me how to get it to go lower ?
I looked in the Kubota manual and there are two holes on each horizontal link/lifting arm. If you hook the lifters to the holes which are closer in towards the tractor you get more vertical movement of tools connected to the 3PH (and less lifting capacity). But just eyeballing it, even if I use these holes which are closer in, it doesn't look like I'd get substantially that much more vertical downward movement of the Middlebuster (though I'm certainly game to try it). I had no trouble digging down the 8-9 inches but it appears I can't go any deeper not becaue of the soil or the Middlebuster, but because there isn't enough downward travel of the 3PH.
Thanks for any help.
Bob
/ Making Middlebuster go deeper #2
Bob
I think you should change the angle in which the furrower enters the soil my manipulating the upper link by extending it out. That will cause it to dig in more agressively. I know I can do it with mine but I prompltly use traction as I have turf tires.
/ Making Middlebuster go deeper #3
I don't think changing the angle of it is going to help due to the limiting factor is how low the arms on the tractor will go. It sounds like it is time to drag out the welder and either extend something, or change the mounting points to allow it to go lower. The drawback to that is making sure it will still raise the bottom high enough to clear the ground when you want to transport it to the next spot.
David from jax
/ Making Middlebuster go deeper #4
I agree with this aprroach. Remove all implements from your 3PH, and watch your arms drop all the way to the ground. If they do, then you need to play with it to find out what angle to adjust the plow.
/ Making Middlebuster go deeper #5
Bob
Are you certain that the 3pt lower arms are in the float position?
I have a B7510HST and the KK middle buster/subsoiler combo from TSC. This time of year with rain-softened soil, I can get the MB at least 12 inches into the soil.
Last week I was digging trenches for PVC lawn sprinkler pipes using the subsoiler frame with a 6-inch-wide chisel plow sweep that I got from Agri-Supply. Had no trouble getting that sweep 12" deep in the ground and holding it at that depth with the 3pt control. In the float position, that sweep was digging about 16" deep.
/ Making Middlebuster go deeper #6
What p/n is the 6" chisel plow sweep?. I looked at the Agri-site but didn't see anything called a "chisel plow sweep". I'm looking to buy the same combo this spring for trenching
/ Making Middlebuster go deeper #7
What is the purpose of needing to go deeper than 8"? Any pics?
/ Making Middlebuster go deeper #8
The numbers on the invoice are:
/ Making Middlebuster go deeper #9
/ Making Middlebuster go deeper #10
Here are a few photos of the 6"-wide chisel plow sweep that I attached to my KK middle buster/subsoiler frame. Fortunately the two holes in the sweep align OK with the holes in the subsoiler frame.
You can see from the dirt on the vertical support that the sweep pulled the frame down almost to the horizontal support that carries the pins for the 3pt lower arms.
For sprinkler pipes, 6-8" depth is enough.
I also use the sweep to dig trenches for water lines from the well to several sheds that I've built recently. I like to get these lines 12" deep.
/ Making Middlebuster go deeper #11
That XB is actually for a sub compact. Maybe BCARWELL has the yellow one which is the model for compact tractors...???
/ Making Middlebuster go deeper #12
ever laid water line?
ever buried electric cable? telephone cable to your shop or building? irrigation line below frost level? I have had a drainage problem from ab out 15 acres and used a middle buster to put a dent in the problem, but I really wish I had a deeper ditch.
/ Making Middlebuster go deeper #13
Here is my 12" ditch and buster at full bite. It is nice to have top and tilt;)
/ Making Middlebuster go deeper #14
Bob
Seems we are getting two opinions on this post. Some think that changing the angle, or having TnT would be an advantage to solving this problem, but if I have read the original post correctly, the problem is simply that the lower arms won't allow the middle buster to go deep enough, dispite the angle, dispite the type of dirt/mud/rock/sand that it is being pulled thru. Yes, doing these things would help if he wasn't already at the bottom of his 3pt hitch travel, but he is, and although there are several ways of fixing the problem, the ultimate need will be to extend it some way or other without getting it too long. Too long will cause the problem of not getting it out of the ditch when you are finished, dragging the ground in route to the area to be trenched.
An interesting way to have both full depth and be able to retract it far enough, especially with smaller tractors would be to cut the main vertical bar and add a slip joint, using a couple of drilled holes to be able to raise and lower the digging tip by changing the position (which hole the pin is in).
It is actually an easy fix.
A more complicated way would be to add a hydraulic cylinder to the shaft and raise and lower it (past the 3pt arms available travel). This would allow you to get to a depth controled by how much hp and traction your tractor has, and approach a point where parts break if you hit something immovable below ground.
For those members that are fabrication oriented, modifying a reese hitch from a p/u truck by welding pins on a center plate at each end of the square 4" frame, allowing it to spin from a horizontal position (where you could use it to pull trailers) to a vertical position, where you could slip a 2x2 square tubing in it with the correct tip. A top link attaching point would need to be fab'ed to hold it in the correct position, but since it would be compression, it wouldn't need to be that high up.
David from jax
I <think> that's the problem (bottoming out on the travel) as it digs down 10 inches or so and just doesn't go any further and I can't think of anything else impeding it being able to go further (e.g. I'm not hitting rocks, etc.) And you're correct, I have to be able to get it out of the ditch. I have had a similar problem in digging with my post hole digger, e.g. about 1/2 the auger is left above ground, and I can only get a 2 foot hole or so. The auger works fine, and I periodically pull it up to take the dirt out of the hole, so its not a matter of the auger getting bogged down by too much dirt surrounding it. If I could dig 2 feet from the surface down 2 feet, it seems like <starting> 2 feet below the surface I ought to be able to go another 2 feet IF the auger could travel that far down. But it looks like the depth of travel of my 3PH, regardless of whether I have a subsoiler or a post hole digger, is about 1-2 feet. I think if there was some way to extend the reach of the subsoiler so at the uppermost reach of the 3PH the subsoiler was contacting the surface of the trench down 10 inches or so (from the first pass), that in a second pass I should be able to go down another foot or so IF the 3PH could be made to go that low. Maybe I need to fashion some sort of downward extender as suggested...
I think I'm going to have to use my tractor, as I didn't like the story I was getting from the rental store about $100 service charges if I threw a chain or broke a tooth on a rented trencher or rock saw. For $100 I could probably make something that would extend my perfectly fine and functional subsoiler downward another foot.
Bob
/ Making Middlebuster go deeper #16
I don't understand that. In the float position my lower hitch arms go almost to the ground. With everything removed and the 3pt hitch in float position, how low do your lower arms drop down.
/ Making Middlebuster go deeper #17
Extending the length of the lower arms on your 3pt will increase the travel distance of the middlebuster. Just a thought, but be carefull with your Engineering! You don't want to break something due to the increase of the mechanical advantage/disadvantage of longer arms.
David from jax
/ Making Middlebuster go deeper #18
If you look at pic posted, and at drawing, I think you can see how you can make an adjustable depth buster using a couple of reciever hitches welded to an upright piece of square tubing. Then get square bar with holes, so you can raise and pin at required depth. Also, if you move placement of arms to hole closest to tractor, this will give a little extra depth. Hope this isn't too confusing, but I bet you can make it work.
  • Buster 1.pdf
  • Buster 2.pdf
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
