Making Hay
/ Making Hay #21
I make 4x6 round bales with a Vermeer 604K, cut with a Kuhn 800 HD and rake with a Hodge Built 10 wheel rake. I use a JD 4230 or a JD 4020 tractor. I try to make as many bales as I can for my cattle and have made 90 bales so far this year.
/ Making Hay #22
1000 squares
41' Farmall H
53' Ford NNA
JD 790 (actually don't use it much for hay)
JD #5 sickle
International Bar rake
New Holland 67 Baler
Looking for a tedder had a Fahr but it was junk, too many hot suppers
No Payments
/ Making Hay #23
1000 squares
41' Farmall H
53' Ford NNA
JD #5 sickle
No Payments
Nice looking family!:)
Your operation is really impressive. Especially haying with all that vintage equipment--that's really neat.
Congrats on your success.
/ Making Hay #24
1000 squares
41' Farmall H
53' Ford NNA
JD #5 sickle
No Payments
That, I think, is the key to success!
/ Making Hay #26
You'd be hard pressed to spend every year, on maintenance and repairs, what you would spend on payments for new equipment.
/ Making Hay #27
depends on what you call small repair bills.i know people that has spent $2000 or $3000 rebuilding a disc mower.an they wouldve been better off buying a new cutter.
/ Making Hay #28
That is the key but I am also a tinkerer by nature and that helps as well.
Originally Posted by bigbull338
but you could end up with alot of repair bills an down time as well.
I just put $1400 in the final drives on the JD, thats more than I spent on any other piece of equipment listed. I know a lot of farmers, from a few head to several thousand head, they all have breakdowns. I called my NH dealer for parts for the ford last year with hay on the ground (damaged PTO shaft) The shaft was 3 days out, they offered a loaner tractor, which I declined, and got the parts within 2 days. That was for a discontinued part. Proper maintenance minimizes breakdowns regardless of equipments age, actually I think the old equipment has a better track record because if it wasn't reliable it would have never lasted over 50 years. I bought the JD 790 new and I have never spent in a years maintenance what I did for a years payments on that single tractor.
Thanks for the complements, we love what we do. Some people dream of fishing on a creek bank in the shade on a hot summers day. I dream about watching hay flow off the sickle listening to the pur of my 41' farmall, there is no mower conditioner that can replicate that feeling.
/ Making Hay #29
I use a 3000 Yanmar tractor and a Takakita Mini round baler and bush hog with a hay side Up graded to a sickle mower and I use an old Deere Side delivery rake. Just a hobby and for use around work.
/ Making Hay #30
All my equipment isn't very old (10 years give or take) but its all paid for as well. I still have break downs but you will have them with new equipment as well as old (older) equipment. Some things will just break but basic maintenance will go a long way to avoiding expensive repair bills. A big thing is to go through everything in the winter so you can take your time to look it over well and not rush through it. Make sure everything is oiled and greased properly and look for any worn parts destined for failure. I know if I try to do everything in the spring I end up rushing as there just isn't enough time so I start in the fall when I start cleaning things up to put away for the winter. I give things a good look over and take notice of anything that needs attention and if its serious I work on it over the winter. But its nice to get a list of things to work on and if I need to order parts I can without worrying about a time frame to get the repair done.
Now all I really need is a much larger building with heat and concrete floors so I can store more equipment inside and have it easy to access to maintain over the winter instead of packing things into my existing barns so tight I can't even walk through it.
/ Making Hay #31
Since I was on here last a few years back. I put up a Clearspan Truss Arch building for hay and equipment, 100 feet long, 16.5 feet high and 42 feet wide with a big metal roll up door on the front.
Has a sand ( I had to level the site and put in a retaining wall) but I put the hay on 4x4 pallets, rounds stacked on end, 3 high. The building holds 150 rounds plus the tractors and the hay equipment. I usually have 100 or so left over for the nags to overwinter on.:D
/ Making Hay #32
We have a NH baler, bar rake, and haybine that we allow our friend to use now as we don't make hay anymore for ourselves. He currently makes about 1000 squares a year.
In the day we were making around 500 to 600 rounds a year for 3 small herds of cattle. When I was a young man I used to help my grandfather make around 2500 to 3000 squares for his 2 small herds.
I don't miss loading that bale wagon one bit.
/ Making Hay #33
I'd love to have nice indoor storage, I get the baler and mower inside but everything else lives outdoors. Priorities. More reliable tedder, bigger rake, and more automated bale handling system first.
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
211297 (A62131)
211297 (A62131)
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
