Making gas cans great again
   / Making gas cans great again #162
I use a battery-operated liquid transfer pump, no lifting no spilling.
   / Making gas cans great again #163
Adding a vent to increase the flow was the best thing I've done with jugs with the safety style spout. It empties a 5 gallon jug in about half the time.
The "vents" are super cheap and about a 5 minute installation. Its a tubeless tire valve stem with the guts removed. Search YouTube for it. Works like a charm.
   / Making gas cans great again #164
Which one? I want to get one. Lifting oil buckets 5 feet off the ground and precisely pouring them sucks.
The battery lift pumps I saw were either $20 chinese garbage or $1,000 made in Sveden.
   / Making gas cans great again #165
I paid $12 for one that runs off 2 D batteries has worked great for filling my lawn tractor and generators at deer camp. Been using it for 2 years now.
   / Making gas cans great again #166
Saw this, great news. Reducing gas can flow to a pathetic dribble helped nobody.
So wait. They are only directing the manufacturers to specifically add vents again. So potentially increasing cost a little bit. And you still must have the spring loaded nozzle? ugh
Glad I have all my old cans around still. You can pry them from my cold, dead hands.
Reducing gas can flow to a pathetic dribble helped nobody. True and it caused INSTANT GROUCHINESS
   / Making gas cans great again #167
I like the cheap chinese garbage for fuel and DEF but the one time I tried it with hydraulic oil it couldn't do it.
   / Making gas cans great again #168
Back in the day when I had a long commute, there were no gas stations in my rural area that were open early or late. I would sometimes forget to fill up on the way home so as a backup, I would store some gas in a 150 gal skid tank by pumping it out of the 40 gallon tank on my pickup. That way, I would always have a supply on hand for my small engines, as well as my vehicles when necessary.
You could have charged an EV at home, overnight, much easier. Never be at the mercy of someone else’s working hours.
   / Making gas cans great again #169
I most certainly would have done just that if EV's had been available in the 1990's.
   / Making gas cans great again #170
I bought one of these to transfer 170 gallons of old heating oil from one tank to another about 100 yards away. I then outfitted it with a 10 micron Goldenrod filter. Talk about mixing my metaphors, but I didn't want to take any chances on contaminating the furnace.
All told I have about $300 in the pump, filters and pipe to go to the bottom of the tank. Also a gallon of diesel conditioner, just in case. It took longer to set it up than to pump into 55 gallon drums and back out into the other tank.
SIMIRON SV3 HD VACUUM (A58374)
SIMIRON SV3 HD...
Portable Restroom (A54865)
Portable Restroom...
Rooster Artwork (A55758)
Rooster Artwork...
(2) VINTAGE TROLLING MOTORS (A58374)
(2) VINTAGE...
Moxy MT30S Haul Truck (A55272)
Moxy MT30S Haul...
2019 Elgin V2403-CR-T Broom Badger Sweeper, S/N V2903-7JV8496, Kubota Turbo Diesel Engine, High (A59076)
2019 Elgin...
