Making gas cans great again
   / Making gas cans great again #51
Just take off the spout and use a funnel. If you want a vent, drill a small hole (1/8 in) and plug with nail or stick.
   / Making gas cans great again #52
   / Making gas cans great again #53
Completely agree. Spilling gas is FAR worse than letting a pittance of it evaporate out of the nozzle over time.
Yes in agree! I have used both types of cans and I spilled more with the vent free cans than I ever had with the original cans., I threw the new cans in the trash. With all of the new plastic fuel tanks on mowers and four wheelers that are not strong enough to with stand the pressure mod the new cans it is just plain stupid to mandate them. Im with you I will be using my original cans.
   / Making gas cans great again #54
I remember many years ago, when I was a wee little lad in Minnesota, we used a small one gallon metal gas can to fill the lawn mower. I guess it sealed up pretty good, because one day, I went to fill the mower and it was crushed from the outside in, like an aluminum beer can. I guess the last time I used it was a hot day, and I emptied it, then, after replacing the cap and vent cover must have cooled down substantially to reduce the air pressure in the can and the outside pressure crushed it. I used to be able to take that can, on my bike, to the corner gas station and fill it up for 25 cents!
   / Making gas cans great again #55
These are good, if you can't grab a used 5 gallon DEF nozzle left by the trash.
Problem is you still need a vent.
I've used this on more than a couple of cans.
So ironic that a powerhouse communist manufacturing country has to make and sell products to the US to help us bypass our government overreach....
   / Making gas cans great again #56
I drill a hole in the top back of the handle and put a screw in it. If I need to slow down the flow, I can put my hand or thumb over the hole.
   / Making gas cans great again #57
The environmental fix is one of the most lame things the gubberment has ever done. Only They could take a good idea, let's reduce the fumes, and create a solution that is worse than the problem. Reminds me of the covid solution.
   / Making gas cans great again #58
Now the question is, will the prices for a 5-gallon plastic can drop from $32 back to $12 like they once were.
NOT. :sneaky:
Not a chance. Everything is 20% to 30% higher than it was six months ago. Even here in Montana, plumbers are charging $425 an hour! That's $100 PER HOUR more than last year. Want more shocking news? Wait until you see how much your house insurance went up.
   / Making gas cans great again #59
Thank you for your attention to this matter!
And I thought that my gas can just had the same prostate problems that I do! :unsure:
   / Making gas cans great again #60
Instead of whining about government and buying new nozzles, I put vents in all my unvented cans.
Drill a 1/2" hole and install a tire valve. Amazon.com
Remove the Schrader valve, run a 12-14" piece of baling wire through, and make a hook at the end. Make a slight bow in the entire length of wire. Remove the nozzle and run the wire through the opening and carefully pull the valve stem up through the drilled hole until it's seated.
They don't leak but, if you're a belt-and-suspenders guy, you could put some sealant at the base of the stem where it contacts the can.
Quick and cheap. The can in the foreground, like many cans, has a flat spot tailor-made for a vent, where the manufacturer used old molds with vents.
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2023 CHEVROLET 4500HD CAB AND CHASSIS (A58017)
2023 CHEVROLET...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2025 SDLANCH TRAILED CRUSHER (A58214)
2025 SDLANCH...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
