Making a fueling rig
   / Making a fueling rig #1
IMCA38
SE Nebraska
MF 1225 w/loader, Case 1840 SS, Ransomes 723D mower
Well, I've quickly tired of toting my 5 gallon can 2 miles up the road to get on-road diesel. I called the local co-op and they won't deliver off-road fuel in less then 100 gallon quantities. So, I surmised I need something big enough to make the 15 mile trip to get off road diesel worthwhile. Yesterday I went to an auction and started the process. I picked up the tank/toolbox combo for a bid of $45. 00. The tank is in great shape and looks like it isn't very old. It is actually an auxaliary fuel tank for a pickup, but has been running diesel (you can smell it!). I'd say the tank is about 45-50 gallons which is about the size I wanted. I decided the tool box would be handy to keep my grease gun, hitch pins, etc. I then picked up the 4' x 6' trailer for $35.00. All I need to do now is mount the tank on the trailer and come up with a pump of some kind. The tank has a 2" barrel bung on it but I will have to be careful as the bung is close to the side of the tool box, so clearance will be a concern, but I think I can make something work.
   / Making a fueling rig #2
Nice looking fuel bowser. You have plenty of room left on the trailer for log chains, shovels, rakes, and implements of destruction.
It looks like a diaphragm barrel pump or an electric will fit in the fuel neck, but you may need to use a Dresser coupling or jury rig a coupling.
Thanks.
I think I'm getting the pump part figured out. I want to put on a hand pump so I can use it anywhere. My Massey only has a 6 gallon tank, so I shouldn't get too winded! There is a barrel bung on the top of the tank, but it is very close to the side of the tool box. In addition, the tank is only about 9 1/2 inches deep, so most barrel pumps won't go that shallow. I think I will try to put a galvanized 2" nipple, about 12" long in the bung with a double female union on top, and then put the pump in that. Hopefully that will work ok.
One other thing I'll have to do is put a tongue jack on the trailer. That thing is heavier then heck even without fuel in the tank!
   / Making a fueling rig #4
Is there any need to somehow ground the tank when filling it? I read somewhere here that fuel can should be on the ground when being filled because of static electricity generated as fuel flows through the hose. I'm not sure I agree with that, because rubber tired cars and trucks are filled with gasoline and diesel every day without any ground.
Thanks
Joe
   / Making a fueling rig #5
</font><font color="blue" class="small">( Is there any need to somehow ground the tank when filling it? )</font>
I wouldn't worry about a static spark igniting diesel, but it might not be a bad idea for a petrol bowser.
All you need is a wire and an alligator clip. If you want to get fancy, use a trouble lamp reel, take the lamp off the end and replace it with an alligator clip.
   / Making a fueling rig #6
You do not want to use galvanized pipe fittings with diesel fuel.
Use black pipe fittings instead.
   / Making a fueling rig #7
</font><font color="blue" class="small">( You do not want to use galvanized pipe fittings with diesel fuel. Use black pipe fittings instead.)</font>
LBrown59,
I didn't know that? Can you explain why?
   / Making a fueling rig #9
</font><font color="blue" class="small">( I think I'm getting the pump part figured out. I want to put on a hand pump so I can use it anywhere. )</font>
One thing to consider using is a 12v electric pump - given the fact that whatever you are fueling probably has a 12v battery and will be right next to the tank, it would should allow use "anywhere"
.... and it sure beats having to turn that crank in 90+ degree weather /forums/images/graemlins/grin.gif
   / Making a fueling rig #10
.... and it sure beats having to turn that crank in 90+ degree weather /forums/images/graemlins/grin.gif )</font>
I agree with this but I'd like to find a pump for less than 150 bucks .
35 to 75 bucks is more my speed.
WACKER NEUSON EZ36 EXCAVATOR (A52705)
WACKER NEUSON EZ36...
2011 INTERNATIONAL PROSTAR TANDEM  AXLE MID ROOF SLEEPER (A54313)
2011 INTERNATIONAL...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
