Making a counterbalance for my mx5200...give me your opinions...please
   / Making a counterbalance for my mx5200...give me your opinions...please
I would suggest putting bigger bolts in the top-link bracket and bolt a piece of steel between the bolts on the inside to keep the bolts from possibly pulling out of the concrete.
There is no way they will pull out with the washers nutted on the ends like shown in the picture. Did you notice those?
Concrete weighs in at about 150 lbs per cubic foot... Find capacity of barrel in cubic feet and multiply by 150....
How to Calculate the Volume of a Cylinder (with Examples)
A common 55 gallon steel drum (cylinder) has a volume of 7.35 cu-ft.... 7.35 cu-ft X 150 lbs =1102.5 pounds (approx)
It will take approximately 18, 60 pound bags of "Saccrete" to fill 55 gallon drum at about $3.40 a bag... About $65 for concrete...
Dale
I did all those exact calculations but I've only seen the concrete with a density of 110lbs per cubic foot. I don't know what number to trust. Is that generally listed on the bags?
All bolts are 1/2" galvanized. I didn't find where galvanized would have a problem reacting too terribly with the concrete.
   / Making a counterbalance for my mx5200...give me your opinions...please #24
It was just a suggestion.
   / Making a counterbalance for my mx5200...give me your opinions...please #25
This is where I got my numbers....
Concrete Weight Calculator - Estimate the Weight of a Concrete Structure
I made a 2X2X1 ft box (4 cubic feet) and filled it with almost 9 bags of 60 pound per bag sakrete... Lost a little volume due to putting some(4) 2 inch ABS pipes in box for tool holders (shovels, rakes, hoes) .... Numbers seem to work...
Dale
   / Making a counterbalance for my mx5200...give me your opinions...please #26
One thing to consider with ballast boxes is that the goal of having a heavy ballast "nestled in close between the tires" (as has been mentioned in a variety of other threads, not this one) may make the rig more maneuverable, but the closer in to the tractor it is, the heavier it has to be to have the same FEL counterbalancing effect, because of the lever action.
It would be interesting to me to see a ballast box set up with a variable attachment, so the box could be pulled in tighter for lower weight FEL work when clearance is important, and extended farther out away from the rear axle to better counterbalance the FEL load. If the center of the ballast box is typically 4' from the rear axle, moving it a foot back would be equivalent to adding 25% more weight to it.
   / Making a counterbalance for my mx5200...give me your opinions...please #27
I made this one from a pickle barrel. Dropped in (10-1/2) 80lb. bags. At an estimate of 86 lbs/bag cured + the barrel, stabilizer, and other pieces, I think its around 930lbs.
I dropped in a couple pvc pipes for tool storage if needed, and didn't pour all the way to the top. I store chains in the top and lid still screws on.
Where are you guys getting those top link connectors?
Also, what is the easiest way to get concrete into this? Do I need to mix it and then pour it in? Or can I just open the bags into the barrel and add water in and leave it be?
   / Making a counterbalance for my mx5200...give me your opinions...please #30
LOT: (9) Wheel Loader Shanks (A59076)
LOT: (9) Wheel...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
