making a chipper for a PT?
/ making a chipper for a PT? #11
J_J said:
Just some data that someone might can use.
Hydraulic Pumps & Motors
Pumping = 1 Hp = 1 GPM x 1500 Psi
(linear relationship i.e. 2 GPM @ 1500 Psi = 2 Hp)
Hp to drive hydraulic pump = Psi x GPM / 1714
Efficiency - typically assume hydraulic pump/motor efficiency of 85%
Hydraulic motor torque (in-lb) = Pressure (Psi) x motor displacement (in3/rev) / (2 x Pi)
Hydraulic motor speed (RPM) = 231 x GPM / motor displacement (in3/rev)
Hydraulic motor power (Hp) = Torque (in-lb) x RPM / 63025
The PT 422 and 425 are rated at 8 GPM at 2500 PSI = 20,000 somethings. Divide that by 1500 and you get 13.3 horsepower. 13.3 * .85 = 11.33. Sorry for my previous memory of 15 horsepower. That's what I get for counting on my memory. Thanks for the lession J_J.
/ making a chipper for a PT? #12
Bob, this is not stuff that I keep in memory either. I give credit to the age of computers, and the Internet.
/ making a chipper for a PT? #13
OK. now I am going to show how bad I failed physics. The 1850 is rated 8GPM at 2500PSI.. So, wouldn't it be 11.33HP? I am missing something huge here...
/ making a chipper for a PT? #15
I believe the 1850 is rated at 18 gpm, at 3200psi
/ making a chipper for a PT? #16
I would think that if you could find an old chipper that ran on a 10HP or less motor you could adapt it to a hydraulic motor very easily. Those gas engine chippers usually turn the engine at 3600 RPM and have belts that drive the chipper. You would have to gear up a hydraulic motor with pulleys of the proper size to get the chipper to turn at the original speed.
I seriously thought about this a while back. I even went to a lawn and garden dealer that has some used chippers. I could have picked one up with no engine for about $300 and then put another 3-4 hundred in a hydraulic motor and pulleys, etc... it looked to be a very doable project. However, I realized I have little use for a chipper right now. Maybe in a few years.
iDrive TDS-2010H...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
2018 HINO SA (A58214)
2001 INTERNATIONAL 4700 BOX TRUCK (A59906)
2001 INTERNATIONAL...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
