Making a beam pole ?
   / Making a beam pole ? #1
bcarwell
Austin, Texas
Kabota 7500DT
I saw a picture here of a guy who connected some sort of 10 foot or so pole to his FEL and was using it to lift rafters in place. I think they called it a "beam pole" or some such.
Does anyone know where I can buy such a beast, or exactly how they connect to the FEL or how I could build or jury rig one ? Can't be too complicated, but sure beats my last solo build of a 30x30 metal building where I had to hoist the 300lb trusses into the air suspended at either end from landscape timbers stacked vertically on end strapped to the corner posts with pulleys dangling 15 feet up, using come alongs at either end. Would sure like to lift with my FEL instead this time !
Farmer Bob
   / Making a beam pole ? #2
I made one from 3 1/2" pipe for my old Backhoe. I simply welded a piece of 4" channel across the bottom end to sit on the cutting edge and have 2 chains that run from the end of the pipe to hooks on the top of the bucket. I ran a chain all the way around the bucket and dogged it tight to keep it sitting on the cutting edge. It worked great to sit thr trusses on my shop. I sold the backhoe, but kept the boom pole to use on my son's skidsteer. HTH. Later, Nat
http://www.countrybynet.com/attachments/files/28120-new house 034.jpg
Couldn't get the thread to come up Ron. Could you please check it, as I'd sure like to look at it. Maybe its my browser or something. I'll keep fiddling..
Bob
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
2018 CASE IH 110N LOT NUMBER 223 (A53084)
2018 CASE IH 110N...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
