making 3pt impliments compatable with imatch
   / making 3pt impliments compatable with imatch #1
indyjim1
is there a part available to make 3 pt equipment compatable with imatch
I have a CM tiller and several other pieces (seed spreader etc)
I am looking for something to bolt or weld on the equipment ot make it imatch compatable
   / making 3pt impliments compatable with imatch #2
When I had my Imatch I had to modify a couple attachments to work. Usually it just involved adding a top link pin and bushing in a lower location than the original. If you are handy, and especially if you weld, you'll have no trouble. Sometimes its as simple as drilling a couple holes.
   / making 3pt impliments compatable with imatch #3
There is no ready made parts available. Each implement will require a different solution to make it fit. But when you are done you will smile from ear to ear at the pleasure of hooking up a heavy implement with the I-Match.
   / making 3pt impliments compatable with imatch #4
You do not say just what the problem is. To make one of my implements work I had to weld a 2" square tube to each side to build the width and drill the tube for the bottom pins. Another just installed longer bottom pins. Another had to take the A frame off and space it out with pipe spacers. Some work with the hook some with the adapter but like kennyd said just look at it find a game plan and if that does not work look at it some more, my bb is still not right after 3 or 4 tries, finally measured and discovered box was not welded square.
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2008 FORD F-350 (A52472)
2008 FORD F-350...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
MANLIFT (A52472)
MANLIFT (A52472)
