maintnance for a old tractor?
   / maintnance for a old tractor? #1
seabass
ontario
Hey Guys, I just bought a Universal 640. It work really good. I dont have any problem with it. I'm just woundering what should i do to it regarding maintenance, because its been parked for a few years? Should i flush every fluids in it?....
Thanks?
   / maintnance for a old tractor? #2
I would change all the fluids. My dad bought a nice looking JD B a few years ago in the fall. When it got really cold it wouldn't move due to ice in the trans that had frozen. Got a few gallons of water out of that thing.
M.D.
   / maintnance for a old tractor? #3
Yeah, flush out all fluids. You may need to do it twice after running it around a short time to get all the stuff up and out.
Check all the grease fittings. You may need to replace some. May need to repack the bearings. Definitely clean the air filter. Probably an oil bath unit. Check, adjust, repair the brakes.
jb
   / maintnance for a old tractor? #4
If it's a diesel, chang the injector pump oil.. if it is a model with an oil sump, and not fuel lubed.. etc.
soundguy
   / maintnance for a old tractor? #5
I'd say tighten all the bolts too.
The good thing about changing all the fluids and filters is that you know where you're at.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
