rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,892
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
The biggest complaint is that the TSC fluids cause a much louder whine in the HST. No failures, just poorer all-around performance.
Most go back to UDT/SUDT.....
Now if an extra loud HST whineing away whilst you work doesn't bother you, the TSC equivalent HST fluids should work fine. Carry on
Dave
It's hard to generalize. The whine might just be a case of that particular oil in that particular tractor. On our M59 we changed to SUDT at 244 hrs - and the HST immediately got so noisy that we changed back to regular HST fluid at 302 hrs. It was an expensive experiment. The increased whine and rattle from the HST with the SUDT was taking too much of the enjoyment away from our tractor time. After changing back, the noise level is noticeably reduced. Everything works better. The HST pump rattles less when the tractor is cold, and the normal HST whine is noticeably reduced as well. Even the hydraulic cylinders slide more smoothly. It's not a matter of it being "maybe less noise"; the noise is now a tiny fraction of what it was with the SUDT.
Time will tell us more, and of course someone else's experience may be entirely different.
BTW, our whole SUDT experiment makes me wonder to what extent that Kubota is involved in the manufacture and/or testing of SUDT? Our SUDT had to be special ordered and came in sealed black&orange Kubota 5 gallon containers. But the pasted-on labels on the containers indicate it was made and packaged by someone else.
rScotty
