Maintenance Filters
   / Maintenance Filters #1
perdurabo
So I'm coming up on the dreaded 50-hour maintenance for my L3400HST and since I'm doing myself I'm looking to save some money on filters and consumables. I've already discovered I can get hydraulic fluid and oil cheaper at TSC, thats a no brainer, but what I can't find is an alternative to my Kubota dealer's pricing when it comes to filters. Here's what the dealership recommends as far as filters:
HH164-32430 Oil filter
TA040-93220 Air filter inner
TA040-93230 Air filter outer
HH3A0-82623 Hyd ASSY Filter
HHK70-14070 Hyd cartridge filter
6A320-59930 Fuel Filter cart
I ran all of these through various cross reference engines (fleetguard, baldwin, wix, napa, carquest etc) and though some of them had crosses (the air and oil filters), the hydraulic and fuel filters generally didnt... and what crosses there were were generally about the same price as my dealer. The HH3A0-82623 HST tranny filter in particular seems VASTLY overpriced at $33. I just can't imagine any spin on filter actually being worth that for any reason whatsoever other than to screw me out of as much money as they can, but I just can't find any crosses for it.
Anyone who has already done this maintenance successfully find crosses that work and are cheaper than OEM filters?
If I HAVE to use OEM filters, is there anyplace that sells these in a "kit" form that gives you a discount for buying all of these all at once?
   / Maintenance Filters #2
I am also doing the 50hr service this coming weekend on my GL3240. Best price I could find for Kubota brand filters is via eBay. Check out Vacwizard as they offer package deals on filters. I purchased a package for my tractor. Vacwizard is really - Canns-Bilco - bush hog, bush hog parts, lawn mower parts, riding lawn mowers, honda lawn mower parts, log splitter, atv mower, snowblowers, Lawn Vacuum, briggs and stratton parts, Troy Bilt parts, kubota tractor parts, kubota oil filters, bush hog, b.
To be honest, considering the amount of $$$ I have tied up in my tractors I can't see using anything but Kubota filters and SuperUDT. I do use the Mobile 1 Turbo Diesel Truck 5w-40 full synthetic (from WalMart) for the engine oil but everything else is Kubota.
   / Maintenance Filters #3
I can see buying synthetic oil or other high quality oil over Kubota dino, if that' your desire.
I can also see buying a super high quality oil filter, and save money doing it. Same with air filters Completely understandable.
My enthusiasm begins to wane when talking about HST fluid. Buying the same quality, by using another OEMs high quality brand or a top quality synthetic can actually cost more.
My appetite for "cross referenced" hydro filters is virtually nil.
My enthusiasm begins to wain when talking about HST fluid. Buying the same quality, by using another OEMs high quality brand or a top quality synthetic can actually cost more.
The TSC Traveller HST fluid says explicitly on the package that it meets or exceeds the standard for Kubota UDT and John Deere 303. Thats good enough to maintain a warranty and thats good enough for me, especially when its less tan half the price. I personally don't think Kubota's UDT is twice as good because its twice the price, I think its far more likely that Kubota think they can a$$rape me by charging me more than twice what the product is actually worth.
   / Maintenance Filters #5
It's a free country, it's your tractor and lots of folks use the TSC products, apparently with little complaint.
That said, you noted it meets udt, but not sudt. The sudt standard is harder to meet. Also, backing up a bit, are you sure, absolutely sure that your manual calls for dumping all your fluid at 50 hours? Many of the newer schedules only call for filter/screen changes and cleaning at 50 hours, with the fluid not being dumped until 300 hours.
If economy is your primary focus, you'd save the most, by far, by leaving the fluid in there until 300 hours, if your schedule calls for that.
   / Maintenance Filters #6
Do what you want, but the risk is not worth the reward. If you buy a painfully expensive tractor, why would you cheeze out on the maintenance..Makes no sense to me.
Services are no place to save a buck...if a filter can't handle the pressure or doesn't have a bypass, then what? That 3 bucks you saved will cost you 3 grand.
If you blow an HST on TCS fluid, try selling that one to Kubota Service..They'll tell you to take it up with the generic fluid manufacturer...Best of luck on that one.
I've seen this happen, and it ain't pretty.
   / Maintenance Filters #7
There was a Kubota filter kit that I bought when i did my 50 hr service. I also got a Kubota hat inside it :D
   / Maintenance Filters #8
I believe there is now No oil that meets SUDT. There was one claiming that it did, but Kubota took them to court and won because it fell so short. It was more like UDT than SUDT.
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
1997 Ford Tandem Dump Truck (A59814)
1997 Ford Tandem...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
