Maintenance Costs
   / Maintenance Costs #1
chim
Elite Member
Lancaster County, PA
Kubota L4240, Ford 1210
Today I stopped at two dealerships and stocked up on fluids and filters for upcoming maintenance on both a Ford 1210 and a Kubota B7500. Oil and hydraulic filters for both, plus a fuel filter for the Ford. The Ford fluid is their "134" and the Kubota fluid is Super UDT. Total cost was $92.24 for the Ford stuff and $91.87 for the 'Bota. The Ford "134" was $42.94 a gallon, and the Super UDT was $64, but the Ford hydraulic filters were a lot more (over $40 vs. $15).................chim
   / Maintenance Costs #2
"The Ford "134" was $42.94 a gallon, and the Super UDT was $64,"
I sure hope that's for 5 gal. Even at that, I'm sure you can find that stuff at an auto parts house a lot cheaper.
   / Maintenance Costs
WHOAA. You're correct. It was 5 GALLONS of each.........chim
   / Maintenance Costs #4
try Filter One, Wix filters for about 1/2 the price of NAPA and 1/3 of the dealer.
   / Maintenance Costs
I'll have to check them out next time. Do they make hydro filters? Sounds promising for the old Ford.
For the Kubota I don't mind spending a few extra bucks to use Kubota filters and fluids because of warranty concerns. It's worth $40 a year to eliminate the "sorry, you used an inferior filter" argument.............chim
   / Maintenance Costs #6
Yep, get mine from my auto parts place. You can cross the numbers here Wix or I can check my numbers at home. Hydraulic filter is #51736.
   / Maintenance Costs #7
You should be able to get a warranty statement from Wix that they are factory or above specs. Wix also makes Napa and Carquest filters.
The Wix filters are approved for Cummins, Cat, and Detroit diesel engines. I sure would think the major tractor brands would also be covered.
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
John Deere 5075E (A50120)
John Deere 5075E...
2015 Z Master Professional 5000 Series 60in Zero Turn Commercial Mower (A50322)
2015 Z Master...
2013 Kubota M9960 (A50120)
2013 Kubota M9960...
KJ U-Type Shackles (A50121)
KJ U-Type Shackles...
