MAINDRA 3616 HST FRONT RIMS
   / MAINDRA 3616 HST FRONT RIMS #1
Renbenrn
Mahindra 3616 HST
Hi does anyone know where you can get replacement rims for a 3616 HST OEM or other? Mahindra parts catalog doesn't list and internet search isn't helpful. Are Mahindra rims standard between similar tractors like the 3616 and 1635? The Tires are 28x8.5x15. It may be an easy question, but I mainly use it for snow plowing and moving hay bales, I am a nurse by trade.
   / MAINDRA 3616 HST FRONT RIMS #2
You need to match lug pattern, hub diameter, and offset in addition to the basic diameter/width. Note that tractor wheel dimensions are typically taken from the tire seating surface and not necessarily the rim lip.
When you have those dimensions I suggest calling Hey Wheel in Kansas -not much of a website but they can source or make whatever you need. I've used them a couple of times for oddball wheels.
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
378467 (A51572)
378467 (A51572)
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
