MAINDRA 3616 HST FRONT RIMS
   / MAINDRA 3616 HST FRONT RIMS #1
Renbenrn
Mahindra 3616 HST
Hi does anyone know where you can get replacement rims for a 3616 HST OEM or other? Mahindra parts catalog doesn't list and internet search isn't helpful. Are Mahindra rims standard between similar tractors like the 3616 and 1635? The Tires are 28x8.5x15. It may be an easy question, but I mainly use it for snow plowing and moving hay bales, I am a nurse by trade.
   / MAINDRA 3616 HST FRONT RIMS #2
You need to match lug pattern, hub diameter, and offset in addition to the basic diameter/width. Note that tractor wheel dimensions are typically taken from the tire seating surface and not necessarily the rim lip.
When you have those dimensions I suggest calling Hey Wheel in Kansas -not much of a website but they can source or make whatever you need. I've used them a couple of times for oddball wheels.
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
John Deere 853 20ft Corn Head (A53473)
John Deere 853...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
