Main Sewer Line
   / Main Sewer Line
Quote:
Originally Posted by CurlyDave View Post
The other option might be to rent the machine at close of business on Saturday and return first thing Monday.
That is always my strategy...
I like the strategy... I'm thinking about driving down Thursday night and taking Friday off to do the repair. I could clean up the excavation on Sat morning, if I can't finish on Friday... If I rent a machine, I'll replace all 50'...
   / Main Sewer Line
I am a plumbing contractor. I just replaced 25' of the hardest to get to pipe I have ever seen. I had two concrete porches, two cable vision lines, two water lines, two air conditioners, a criscross of gas lines and tree roots as big as your leg. I did it by the hour and it cost the customer $1250. I don't work cheap. I had my own machine and and another plumber on the job. I could almost drive out and do your job for $2300.
Just as I suspected, that my daughter was getting overcharged... Years back I had a dump truck and IH 3400 BH.. I did a lot of trenching for plumbers back then and installed sewer & water line for one plumber when he was busy.. He did pay extra whenever I helped or did the work. I hung up that extra work when OSHA went Ape about using trench boxes...
Correct me if I'm wrong, but I'm thinking a 25' repair / 18 to 24" deep in a wide open area without other utilities should run about $850...
   / Main Sewer Line #13
I gave the customer a "guess " before I saw the utility marks of " less than a thousand" . So $850 would be reasonable, but I don't think you would get anyone to bid it for that. You always have to leave some room for the unexpected.
   / Main Sewer Line #14
1. Charlotte is a pretty big city. Call around for rental yards. I have the choice of about 6 within 10 miles of Redwood City, CA. Both equipment and charges vary from yard to yard. Many yards do not rent excavators with a thumb, the lowest priced yard has one with a thumb, just as an example.
2. You are going to need some fill to correct the settling problem, think that one through before you start driving. I am thinking gravel pushed down into the soft mud near the settlement, using the hoe. Decide where you are buying, how it is getting there, and what to do with any excess.
Maybe a pro will chime in, but I am thinking that replacing good sections may be asking for future trouble. If it ain't broke, don't fix it. Just do the section that has settled.
3. Before you replace any of the pipe diagnose what is really wrong. If it has just pulled apart, all you need is couplings and fill. Re-use the pipe, otherwise you have a disposal problem at the end of the job.
Good luck
   / Main Sewer Line
Good luck
Back when the house was built in the 70s, it was common practice to dig a pit and bury the construction waste.. There's a sink hole in the yard where the sewer line settled....
   / Main Sewer Line #16
That is common here now due to burn laws and I know of some that will have this same problem some day. Things for stating the cause of the problems.
   / Main Sewer Line #17
Home Depot got into the rental business in Tennessee, and I would guess you could rent a small backhoe there any day of the week in Charlotte, NC. You could always call the store nearest your daughter's place and ask.
   / Main Sewer Line
There's a LOWEs nearby that has a SUNBELT Rental Center..
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2018 FORD F250 XL EXTENDED CAB TRUCK (A51406)
2018 FORD F250 XL...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A55788)
2009 Ford F-250...
Killbros 450 Gravity Wagon (A50775)
Killbros 450...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
(APPROX.100) UNUSED FUTURE 12' GALVALUME STEEL TIN (A54757)
(APPROX.100)...
