Main frame kit for B7500 or other B series tractor
   / Main frame kit for B7500 or other B series tractor #1
dannyk
Northern Minnesota
Kubota and John Deere tractors 20-40HP; skid steer loader
I notice in Kubota's B-series literature that a "B2002 Main frame kit" is required for use of a rear blade. Rather odd, thinks I. Does anyone have this kit and can you describe it? Is it necessary for all ground engaging tractors in the B series? Does it reduce ground clearance? Thanks to any responders in the know on this issue.
   / Main frame kit for B7500 or other B series tractor #2
That's a new one on me. I have a B2400 and have never heard about a B2002 Main Frame Kit.
Hey Muhammad, have you heard about this one?
   / Main frame kit for B7500 or other B series tractor #3
I'll take a stab at it, but I'm just guessing.
First of all, it's not something required of the B-series tractors for non-Kubota implements.
What I think Kubota might do is have one common "rear frame" that they use for their rear blade and maybe a few other items, like a landscape rake or plow or something(?).
I've seen mention of a front frame necessary for snowblower/snowblade and sweeper attachment, so I'm guessing this is something similar.
I think the majority of us here use other than Kubota implements, so we might not be up to speed on all the specifics of Kubota implements.
~Rick
   / Main frame kit for B7500 or other B series tractor #4
Beats me. I did add a top link brackt from the backhoe kit which is much stronger since I boxblade in reverse a lot. I am not sure what they are talking about unless it is something specific to a Kubota implement. My 2410 works just fine with all 3-point type implements attached to the standard3-point. I would not worry about it since none of us seem to have whatever it is /forums/images/graemlins/crazy.gif. J
   / Main frame kit for B7500 or other B series tractor #5
The one thing I do wonder about is the Narrow variant of the B7500. That B unit is a version that is only about 35 inches wide. I wonder if it needs a sub-frame of some kind to add rigidity to the rear axle assembly?
   / Main frame kit for B7500 or other B series tractor #6
dannyk
The B2002 is actually part of the rear blade. When you order a Kubota rear blade, you need to order the moleboard (either a 48" or 60") and the main frame kit have a complete grader blade.
Lewis
   / Main frame kit for B7500 or other B series tractor #7
Ditto to what Equipment man said. I have used a Woods RB60 for many hours on my B-7500 without any problems. /forums/images/graemlins/wink.gif
   / Main frame kit for B7500 or other B series tractor #8
That almost sounds like a way to nickle and dime somebody.
   / Main frame kit for B7500 or other B series tractor #9
Or it could be a way to get two sizes without having to buy two complete assemblies. This way you could use either the 48" or 60" blade.
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2017 F-550 Bucket Truck (A51039)
2017 F-550 Bucket...
