Main electric service line too long?
   / Main electric service line too long? #1
bebster
Platinum Member
Cape Cod, MA
JD 4410 eHydro & 430FEL w/ 4N1 bucket & pallet forks
To those who replied to my recent Cat5e pulling post -- thanks! I am also planning to run by main electric service line from the pole to the house. Total wire run is 400' from the pole to the main panel. My electrician is suggesting using "0000" gauge wire and burying it in 2 1/2" pvc conduit. Yesterday the electric company suggested that is too marginal and the voltage drop will be too high, and I should run a primary up close to the house and put a transformer pad there. Any suggestions? I was just about to begin digging the trench with my tractor next weekend!
   / Main electric service line too long? #2
I'd go with the electric company recommendation. Usually, that's their nickle anyway other than an upcharge for underground versus above ground wiring. Our house is about 500 feet from the utility lines and we have our own transformer box on the ground. Nice, bright lights all the time /forums/images/graemlins/cool.gif Neighbors are a bit closer and started with a pole hung transformer at the street. Had all sorts of problems with dimming lights and motor start ups. They got the electric co. to give them a transformer at the house and all is well /forums/images/graemlins/smile.gif
Here the electric company will give me a "2 pole" credit toward the transformer and 4' underground wiring. I suspect this isn't that much and the tab will be high. In addition to the cost, this will mean a 2 month delay since I'm sure they'll be slow on the design and construction etc.
I was able to find this voltage drop calculator.
Voltage Drop - Wire Size calculator
If I use copper 0000 gauge wire 400' long and drew the full 200 amps on the main panel, I'd get a 3.9% voltage drop. But I'm not sure if that's too much or not that bad.
   / Main electric service line too long? #4
I've done a fair amount of trenching for underground electric and have one question,, how are you getting away with 2 1/2" pipe when out in this side of Mass and CT for that matter, the electric companies require 4" schedule 40 at a minimum for anything over 200 feet... Also, the sweep to the poles now has to be in steel and no more PVC (just the 45 sweep)
   / Main electric service line too long? #5
I would go with the power company's suggestion. Better to suffer a small inconvenience now over a large one later. Don't know if you have ever worked with 0000 cable, it is like trying to run three 3/4 inch steel water pipes into conduit. It can fit into 2-1/2 conduit but it will be a lot of work, require the right equipment to pull and someone that really knows what they are doing. I think three inch conduit minimum and probably better off with 4 inch if you decide to run your own wire.
Not sure of how the power company charges for installation in MA but in a lot of areas they charge for anything after the primary drop, if that is true in your case, you will save a big bunch of bucks. Check the price for 3ea 400 foot lengths of 0000 copper wire plus conduit and the hook up cost.
IMHP
Farwell
   / Main electric service line too long? #6
definitely go with the power companies recommendation. You want that transformer as close to the house as you can stand it. I'm running 0000 at about 140' and this works well for 200amp service.
   / Main electric service line too long? #7
</font><font color="blue" class="small">( I should run a primary up close to the house and put a transformer pad there. )</font>
Yes, that is what you want.
   / Main electric service line too long? #8
I have 1400' of primary running to my transformer pad 100' away from my house and 100' away from my shop. Best investment I ever made. I had to pay $4.00 per foot after the first 1000' of primary and that was it. All underground btw. That and nothing but 12 gauge wire and hire in my house and I don't EVER have a dimming problem. /forums/images/graemlins/cool.gif
My electrician is going to thread 10' lengths of pvc conduit 2 1/2" in diameter onto the 4-ought wire, and then glue them together. Kind of like making a beaded necklace on the ground, and then placing it into the trench that's 2' deep. He's an experienced guy so I want to give him the benefit of the doubt.
   / Main electric service line too long? #10
two thoughts:
Electric co. will have to spend more of their $ to do what they recommend. You will have a shorter run, thus less $. Electrician wants you to make a long run thus more $ to them. Think about it.
Second point. All conduit is to be installed as a complete system per NEC or NESC and then the wire pulled into it. If conduit is being threaded onto the wire something is wrong with this installation. Again, think about it.
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
Doosan DX85R (A50123)
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
