Mahindra Three Point Hydraulic Problem
   / Mahindra Three Point Hydraulic Problem #1
smstroble
Valley Mills, TX
2006 Mahindra 5500
I have a 2006 Mahindra 5500. I have been using a box blade connected to the three point hook-up, Recently when the blade would strike something, the blade would go up. Now it will not go back down. Does anyone know what this could be or how to correct the problem?
I just checked the manual and it does have draft control
   / Mahindra Three Point Hydraulic Problem #5
I"d suggest that you post a thread in the Mahindra owner operator forum probably find more info there. a draft will cause it to raise when pulling hard or hit something. But it should go back down . work levers up and down to see if this makes a difference.
   / Mahindra Three Point Hydraulic Problem #6
There should be 2 levers. Based on my 7520, the draft control lever should be pushed all the way forward to disable the DF function. That hopefully will restore normal operation.
larry
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2017 Nissan Titan SV Crew Cab Pickup Truck (A51692)
2017 Nissan Titan...
1992 International F-4900 Grapple Truck (A51692)
1992 International...
