Forks Mahindra SSQA Pallet Forks Difficult to Slide
   / Mahindra SSQA Pallet Forks Difficult to Slide #1
bobm6996
Greenfield, Indiana
Mahindra 5010 4WD HST Cab, Mahindra 2615 Gear, Scag Tiger Cat 48", Gravely 42" ZTR, EZ GO Gas Golf Cart
Purchased a set of 48 inch 4000 lb. pallet forks with the new tractor, they are Mahindra brand. Is there a trick to getting them to slide? I flip up the locks and try to slide the forks and it almost impossible to get them to move, any suggestions on how I can free them up a bit?
   / Mahindra SSQA Pallet Forks Difficult to Slide #2
A well greased track helps a lot.
   / Mahindra SSQA Pallet Forks Difficult to Slide #3
My forks have a lift and turn pin to release them. The track must be well greased, forks off the ground, lift and turn release pins and push (or slide) forks from near the top. mine move fairly easy even though they weigh close to 100# each.
   / Mahindra SSQA Pallet Forks Difficult to Slide #4
I don't have those forks, and this is just an idea, but to slide my forks easily I lift up on the fork with my left hand and slide with my right hand. It is very easy to slide when I lift and extremely difficult to slide if I don't lift up on the fork. Again my forks are not the same, and this is just something to try... No guarantee.:)
   / Mahindra SSQA Pallet Forks Difficult to Slide #5
Raise the arms. Tip the forks forward almost to vertical. Should slide easy.
larry
   / Mahindra SSQA Pallet Forks Difficult to Slide #6
I did this. hydro forks 3.jpg:thumbsup:
   / Mahindra SSQA Pallet Forks Difficult to Slide #7
I bought the Kubota OEM forks and then didn't slide well at all. Greasing, oiling, graphite imbedded paint, nothing worked.
So I noted where they bound on the frame and went at them with a grinder. They work great now.
Thanks for the suggestions. Tried WD40, that helped a bit. Will try the grease next, but may have to take the suggestion from gwdixon because they seem awfully tight at the top and bottom. Footer200, you are a genius, that is the way to roll (or slide).
   / Mahindra SSQA Pallet Forks Difficult to Slide #9
I rub paraffin wax or an old candle on the mating parts on mine to move the forks easier. I think it works better than grease. Grease just gets smeared around, collects dirt and gets all over everything.
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
LEEBOY 400T DOUBLE DRUM ROLLER (A52707)
LEEBOY 400T DOUBLE...
2010 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2010 WACKER NEUSON...
2016 Lincoln MKC SUV (A55853)
2016 Lincoln MKC...
2012 PETERBILT 367 WINCH TRUCK (INOPERABLE) (A55745)
2012 PETERBILT 367...
