Oil & Fuel Mahindra spitting and sputtering and it will not start
   / Mahindra spitting and sputtering and it will not start #1
Blackmb
Seneca, SC
Mahindra
Howdy all, lady farmer here. I have a Mahindra "00"Seies 5500, it is a 2002. Just change the oil and filter, began cutting hay made a few rounds and tractor started spiting and sputtering up a small hill. Like it is not getting fuel. I changed all the fuel filters, drained fuel tank put in new fuel, ran like new for 15 minutes. Started spiting & sputtering, and I didn't make it back to the barn, it died on me.
I checked the new fuel filter for trash or debris, and it was clean. I pumped the hand pump on the fuel pump, it started, I then bleed the lines of air. It cranked, ran ok for a few minutes and shut off again. Could not get it to crank again. Could the fuel pump have gone out like that, or could it be the water separator. I once had trouble with a JD water separator. It seems like it is not getting fuel. :(
   / Mahindra spitting and sputtering and it will not start #2
I wonder if a low oil shut off device got activated when you drained the oil.
   / Mahindra spitting and sputtering and it will not start #3
Check the fuel flow from the tank. Did you check for a screen in the tank when you had it drain. Many of the 00 series has a screen above the shut off valve.
Tree Boom (A50322)
Tree Boom (A50322)
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
Hays LT1 Tender (A52128)
Hays LT1 Tender...
2018 CATERPILLAR 305E2CR EXCAVATOR (A51242)
2018 CATERPILLAR...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
