Mahindra Seats
/ Mahindra Seats #1
BamaSteve
OK, It's still Mrs BamaSteve. I'm sure he will post once he's had enough time on the tractor - may be a while...
Have any of you guys tweeked out the suspension on the seat in order to smooth out the ride. Any feedback would be appreciated.
/ Mahindra Seats
OK, I checked in with the dealer and Mahindra has a seat upgrade available - dealer cost is $275, he wants $350 for it
including shipping.
Seat is a high back, has folding arm-rests, tilting seat-back, slide adjustable position (front-to-back) and adjustable gas shocks for set suspension (up/down).
includes a set belt too, I think.
After filling the rear tires with anti-freeze and water the ride is a little softer but my back took a pounding with the stock seat. Going to get the seat this week and may post the results next week if all goes well.
I think this is a very worthwhile upgrade.
Bama . . . . .
/ Mahindra Seats
Well I'm having so much fun talking to myself on this board
that I guess I'll just skip the follow up to my new seat.
But I will say just how hard this tractor rides. Ouch !
Sure is fun though, I've made my first two dirt piles - now
what do I do with them?
Bama . . . . . . . /forums/images/graemlins/smirk.gif
/ Mahindra Seats #4
I'm not sure if my tractor rides any harsher than any other tractor but I am positive that the speed I'm going makes a huge difference! /forums/images/graemlins/grin.gif
/ Mahindra Seats
Beach,
Granted, speed will kill your back on uneven and rock strewn ground. I've learned to slow to a crawl out in my fields.
The stock seat just seems to bottom out very abruptly and my lower back takes all the punishment. I removed the FEL to do finish mowing with the new seat installed and I must say there was a tremendous difference noticed by me. The folding armrests are a big plus also since I can now rest my elbows on them while steering and operating the FEL joystick which after several hours of work makes me less sore and tired.
The seat wound up costing me $312.00 out the door and was fairly easy to install. It is weight adjustable and decellerates my body rather than whacking me against the end-stops when I run over a rock or dip in the ground. Here in North Alabama we have a lot of chert (Gravel to medium sized stones) in the soil so culling rocks is a state pass-time.
I'll try to keep her below 1500 RPM in second-high when travelling from one project to the next in the future. /forums/images/graemlins/smile.gif
Bama . . . . . . . .
/ Mahindra Seats #6
Steve,
I'll talk to you. /forums/images/graemlins/frown.gif
To much air in the tires will make for a really rough ride too.
/ Mahindra Seats
Jerry,
How low can you go?
I'm below the factory recommended 23 lbs now at about 18 lbs
and I have the rear tires loaded with fluid to the top of the rims. Will lowering the front tire pressure help much?
Bama . . . . . .
/ Mahindra Seats #8
It depends on what size of tires you have. What size do you have?
/ Mahindra Seats #9
I have a 4110 Mahindra with a good sized (11 ft) backhoe hanging off the rear and I don't think it rides any different than the JD 710 that I also run. We're pretty rocky here, also.
/ Mahindra Seats #10
I wouldn't lower the air pressure in the fronts by much at all since they are the ones that support most all of the weight that you pick up with the loader. You could go down to about 14-15 psig in the rear, some people say you can go lower but I don't want to riskslipping the tire from the rim. Filling my tires 75% with fluid seemed to help my ride some.
/ Mahindra Seats #12
If they are 17.5x24, you could go to 10-14 lbs. Your front tires are probably in the 7-16 to 8-16 range, if you don't have a loader or you haul very light loads on it you can go down to 24-26 lbs. on the front. If you haul heavy loads on your loader you will need 28-30 lbs.
/ Mahindra Seats #13
I have a 6000 equipped with four wheel drive, FEL and Shuttle Shift Transmission. I am a Stout Lad of 295 lbs and I have the seat adjustment turned up to the max and it still pounds my butt unless I travel at about 10 MPH on the road. I have county dirt roads that I travel between fields and it is a pain in the butt every time you run over a small stone or little depression. I have had an idea that I am going to tryout this week if the weather permits. I have purchased a fun noodle, the foam things that kids play with in the pool and I am going to see if putting some of that under the seat will help ease the abrupt stop the seat makes when the spring is at its limits. What the hay it only cost a buck at WalMart and if it works it will be worth every penny. I will let you know how it turns out.
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
F-450 SuperDuty Flat Bed 4WD (A63688)
F-450 SuperDuty...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
