Mahindra Seats
/ Mahindra Seats #12
If they are 17.5x24, you could go to 10-14 lbs. Your front tires are probably in the 7-16 to 8-16 range, if you don't have a loader or you haul very light loads on it you can go down to 24-26 lbs. on the front. If you haul heavy loads on your loader you will need 28-30 lbs.
/ Mahindra Seats #13
I have a 6000 equipped with four wheel drive, FEL and Shuttle Shift Transmission. I am a Stout Lad of 295 lbs and I have the seat adjustment turned up to the max and it still pounds my butt unless I travel at about 10 MPH on the road. I have county dirt roads that I travel between fields and it is a pain in the butt every time you run over a small stone or little depression. I have had an idea that I am going to tryout this week if the weather permits. I have purchased a fun noodle, the foam things that kids play with in the pool and I am going to see if putting some of that under the seat will help ease the abrupt stop the seat makes when the spring is at its limits. What the hay it only cost a buck at WalMart and if it works it will be worth every penny. I will let you know how it turns out.
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
