Backhoe Mahindra owners. Little help here please.
   / Mahindra owners. Little help here please. #181
Re: Mahindra owners. Little help here please. Not just Mahindra.
Electrical problems happen to all brands.
Neighbors one year old Kubota SV-95-2 should be pushing snow. It is dead it it's tracks waiting for the Kubota Tech, blocking his driveway. I plowed a path thru the back so his family could get out thru my driveway and cleared in front of his machine for the service truck.
I sure like my soft cab. it was 20F this AM and windy.
I was not cold.
I was not cold.
You know, I guess it does. But it sure seems to be few and far between when newer. I’ve never had an electrical problem with a newer model tractor. (By that I mean, oh let’s say 1980 through today. Until this one.) And the even older ones were so simple there was almost nothing that could go wrong. LOL And if it did it wasn’t usually hard to fix.
Nice set up you have there!
   / Mahindra owners. Little help here please. #183
Can anyone help me identify this bolt? I found it on the ground on stone drive outside my barn just before it snowed. We walk this drive a lot between the house and the barn. And my wife and I hadn稚 seen it. Then just saw it late Monday afternoon and picked it up. Luckily, before it snowed.
It looks eerily similar to the bolts that fell out of my tractor a while back when I had the steering problem.
Any help is appreciated.
I don't think it's a steering cylinder bolt. At least on mine, they used a different style, with the washer built into the head. I took a quick look around mine and the only places they used a bolt/flat washer/lock washer setup is on the loader/ROP framework. That looks like a 17mm head? Maybe 19? I would search your loader, ROP and backhoe frames for that missing bolt. After a busy day with the tree puller on the loader, I usually have to snug up some loader frame bolts. Good luck with your hunting.
   / Mahindra owners. Little help here please. #184
Being a diesel mechanic who has seen old trucks and new trucks. Most things go like this:
New equipment tends to have all sorts of issues right out of the gate (if they have them that is). Say for the first year or two. Once it’s all shaken down they go many many years and miles with very little work needed.
Then you start getting one thing after another failing. Typically components, then it gets quite for a bit then it starts to nickel and dime you to death. Again I’m sorry yours was one with issues but hopefully there shaken out of her and it becomes the workhorse it should be.
   / Mahindra owners. Little help here please. #185
Looks like a subframe bolt to me also... check were the loader frame meets the grill guard to the tractor frame
Mahindra has stepped up to the plate and is replacing my backhoe bucket under warranty. Welds gave loose. Thank you again Mahindra.
Tractor has been running/working great since electrical problem fixed by local mechanic.
   / Mahindra owners. Little help here please. #187
Glad to hear! I think things will continue to improve as the company grows and gets more feedback. :tractor:
Still don’t have my new backhoe bucket. Been three weeks since Corporate told me it was approved under warranty. I had to have my neighbor weld the old up so I could get back to work with the hoe. UGH!
   / Mahindra owners. Little help here please. #189
Hmmm that sucks. You'd think the dealer would have an order placed as soon it's approved. It's a stock item of Bradco.
A good weld fixes anything! You have a good neighbor. Id weld it for you if you were my neighbor also haha.
Put mine to work today!
Still no backhoe bucket. After over three weeks, I guess, I had to pay my neighbor to fix the one I had so I could get back to work. Good thing I did. Been almost eight weeks now. They still haven’t shipped it yet. Just went to dealer today. Just shook my head and walked out. Asked them if they could give me something they had in stock. Different size? Since I paid to have this one fixed? They just balked and gave me the “well, next big load should be coming maybe it will be on that one.” LOL Just unbelievable.
Bucket (A55973)
Bucket (A55973)
2019 Ford F-750 Reel Loader Flatbed Truck (A56858)
2019 Ford F-750...
SPRING TOOTH HARROW (A52708)
SPRING TOOTH...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
LOT: (3) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (3) Kimball...
