Mahindra overheating
Status
Not open for further replies.
   / Mahindra overheating #71
jleal said:
That is ashame this machine can not even handle a quadraplegic.
A quadrplegic fixed it and it lasted 7 months. Took it back with same problem.
jleal said:
When I grow up. I want to be just like you UncleBuck
jleal said:
I am sorry for the typo error.You all are right. I personally myself would like to see a quad do that. I am paraplegic.
Unclebuck I know you been folowing my story around. Can I ask you what you use your tractor for. Are you a farmer or go out and do grass cutting jobs.
this machine can not even handle a quadraplegic. A quadrplegic fixed it and it
A typo error twice in the same post on the same word, Have you looked at the keyboard lately, Q and P are on opposite sides of the keyboard,
how about more likely its a LIE, until you get exposed, then its a error.
How about you are a a disgrace for USING peoples disabilities to try and get sympathy and credibility for your phony posts.
Can anyone tell me what tractor CAN handle a Quad/ para plegic
I use my tractor to run over LIARS and PHONIES, especially when they get caught, in my fields, thats why when you said in one of your previous lies, oh excuse me, posts that you run over dead bodies in the lots you cut , it caught my attention :D
Something tells me that day (grow up)will never come,
OH, is that your mommy in the background telling little jimmie to get off the net, :cool:
   / Mahindra overheating #72
This post is for the MODERATORS,
DO YOU BAN PEOPLE FOR LYING
Do you close threads after there is nothing of value to be added
How long would this thread have lasted if it was in the big 3 forums
AS for me , this thread is closed, with or without action by the moderators
   / Mahindra overheating #73
Agree.
   / Mahindra overheating #74
I also agree.....someone please close this thread and put it to bed....we keep going over the same old thing and no end in sight!!!!
   / Mahindra overheating #75
I must admit that SOME of the info he has posted in here is at least partially true. I have personally talked to the people he named at the dealer many times. The issue I have is that there is NO way a person would typo a disability. I HAVE heard of dealers fitting tractors with special controls for paraplegics and have even seen pictures of such, but THAT is never mentioned here. I would suggest a dealer call his dealer and verify what you can.
   / Mahindra overheating #76
Jeremy,
Even if SOME of the info is partially true, it stands to reason that his tractor problems would most likely be due to the following statements that "HE" made:
"I cut grass sometimes running constantly in 6 inches of water."
"Now I have been told I can break a steal marble when I was growing up."
(I'm positive he means steel)
"But like I said I use this machine hard. Very Very Hard. It does the job."
"My problem I should of purchased a little bit bigger machine."
"I have torn this machine up. I run it through ****!!"
"I guess I am going to go out and buy a bigger mahindra to cut the 15 plus acres lots I do. 2615 handles it but little hard. I mean grass that is 15 feet and higher and this is no lie."
Another statement was "Mahindra Sucks".Not just his Mahindra, but Mahindra the company sucks. I know for a fact that is not true. I have absolutely no sympathy for a liar nor any sympathy for someone who abuses their tractor then complains because it didn't hold up to the abuse. I agree with the above posters to CLOSE this thread as it is getting increasingly useless.
   / Mahindra overheating #77
I would rather this thread stay open. The only threads I prefer to close are the ones with constant, " I'm right, you're wrong" arguements. This one is easy, discontinue the discussion with this particular individual. It's quite obvious he hasn't been completely truthfull and he has also been insulting. When threads are locked, I always wonder what part of the discussion I missed, was something deleted. This individuals comments stand on their own and are easy to see through.
Either way, I won't lose any sleep over it, though. :)
   / Mahindra overheating #78
jleal said:
Well after several weeks of posting the board is finally getting back on track Thanks jwcinpk for the input and help. If the head is warp or the head gasket is damaged. Will it cause the engine to get hot. The water is being used up and I do not know where it is going. I do not see it leaking or do I see it burning white smoke from the exhaust. If I thought the gead gasket was bad. I would of changed it already. I might try that but want some input. This has happened from day one on the water. As for the Loctite. Bill told the mechanics several times. Put Loctite on those axle bolts. Well it seems it is holding up right now. Just has the leak in the new axle assembly though. I have thought about running it wothout the side covers but I figured debris would get in there worse. I am going to try that also. I am opened to all sugestions. Thanks again jwcinpk
If you have a cracked head or a leaking head gasket generally you see cross contamination. Oil in the water or water in the oil. Sometimes not. If the water is leaving it's going somewhere. Is it boiling out the overflow? Absolutely it will cause overheating! Have you verified that 1) you have a thermostat and 2) it is opening? Is the radiator holding pressure? Head gasket replacement is quite a job. Sure you're up to that by yourself? That would be the last thing I'd do. After almost everything else. If you end up going there be sure to have the head checked.
   / Mahindra overheating #79
D#$% you would feel bad if this guy checked out!
   / Mahindra overheating #80
shvl73 said:
I would rather this thread stay open. The only threads I prefer to close are the ones with constant, " I'm right, you're wrong" arguements. This one is easy, discontinue the discussion with this particular individual. It's quite obvious he hasn't been completely truthfull and he has also been insulting. Where have I beeN insulting. Is it because I called Mahindra and there reps told me to take it up with bills tractor. So I said Mahindra Reps Suck. if a warranty is not going to be honored on something that has broken becauase of there fault than My Mahindra Sucks. As for the overheating of mahindra. Go to search in the discusion link and type overheating. It only comes up with Mahndra Overheating. Not any other tractor. As for being Disabled. Yes I am handicap in a wheelchair. Everybody makes typo errors. And yes there is a difference from use and abuse and there is a difference from using hard and abuse. Unclebuck stated he used his tractor hard. But it is alright for him to insult me. And its allright for him to use his tractor hard. The only insulting I have done is against mahindra and no persons. You all are the ones insulting me. Read all the post from the start. Where have I insulted someone. And yes call the dealer to make sure about my front axle wheel falling off. Front axles do not fall off from day 3. If that was the case there would be lots of dead people in this world when there wheel falls off on the highway. Why close the board. Is the moderator a Mahindra tractor dealer and the truth is bad for business. LOTS OF MAHINDRAS OVERHEAT OR THEY WOULD NOT HAVE A DISCUSSION BOARD ON IT.When threads are locked, I always wonder what part of the discussion I missed, was something deleted. This individuals comments stand on their own and are easy to see through.
And I am going to keep posting when someone comes and insults me or calls me a liar. I made an offer. I have a tractor here if anyone wants to look it over. Or If any one here that post to this board and in this area. I will go and cut grass with you free of charge so you can tell me what I am doing wrong. Than you can come back and tell it how it is. Like I said. Lets stop the insulting and move to reality here. Please someone call the dealer and verify the wheel problem and the battery problem. And how does an hour meter go out. The last time this machine was in the shop I told them to fix the hour meter. They did not. I told them about the seal leaking on the new axle and I did not hear. Bring it back. So how did I make a new axle seal leak. Now its my turn to insult. What kind of person would think I had something to do with that when the seal leaked from moving about 10 yards of dirt. A machine is not suppose to do that This is bumper to bumper warranty. If they would of tooken care of business. I would not being posting here. So please call bills and verify my story. This is really getting iritating when something keeps breaking especially when it started from day 3 of being new.
Status
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A51243)
2000 TRAILKING...
2017 Jaguar F-Pace SUV (A50324)
2017 Jaguar F-Pace...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
Boat (A50324)
Boat (A50324)
TEST YOUR BID BUTTON! (A51243)
TEST YOUR BID...
