Mahindra overheating
Status
Not open for further replies.
/ Mahindra overheating #61
MUDONTHETIRES said:
Maybe, YOU SUCK, as a tractor owner. One cannot possibly have knowledge of how to own and operate a piece of machinery and post something like:
"I have torn this machine up. I run it through ****!!"
Mud
Maybe it's just me, but if I had a torn up machine that I apparently had taken through **** and back, I would be happy just to be back.:D
/ Mahindra overheating #62
Seems it would be a **** of an "undertaking"!:D
Sorry, couldn't resist!
/ Mahindra overheating #63
That was funny I liked that. Well Yes I have ran this machine hard. If you all read my othert post I also run my car hard. I put 3,000 miles or more a month on it. 2003 ford taurus. Still runs great with no major maintenace yet but changing oil evey 3000 miles that has 135 thousand miles on it right now. I use the skid loader at work hard and never gave me problems. I run my john deere 544 hard and never gives me problems. What constitutes the definiton hard. I use my millermatic hard. It has a duty cycle of 35% which means you can weld for 3.5 minutes per every ten minutes and I use it pass that sometimes. It still works great after 8 years of building fences. Using something hard can also mean using it constantly. If you go to Bills Website
http://billstractor.com/ and check out what he says about the 2615 on the written description and this is what it says "This would be a great little tractor for up to 10 acres." Okay so I have tried to cut up to 12 acres. It does not do it. It takes 2 days. Stopping a cleaning radiator and checking stuff. So this is what I mean by running machine hard. This tore it up doing 12 acres. BUT HEY. THAT IS WHAT BILL SAYS IT CAN DO. This tractor will cut about 5-7 acres a day. The rest you are tearing it up in my opinion. Okay I am happy with that. Thats better than my riding lawnmower. But to have to keep getting off the machine and cleaning the radiator out every 15 minutes. SUCKS!!!!!!!!. So now I am not happy. How many of you have to clean your radiator every 15 minutes on 18 inches of grass. Yes I have droven it through mud. It was fun. It did a great job going through it. My 4 wheel drive blazer goes through mud also and still runs great. I also see many tractors that are the same size as mine up north with snow plows on them. What are they doing with this machine. That is tearing it up. Salt from the roads is the most corrosive thing and hits that metal hard on tractors. And it talks about warranty issues on this subject. And of course snow is wet and there is mud underneath. UHM!!! Most people on this post are farmers. Do you all not pull a heavy plow, Pull tree stumps out of the ground and other heavy stuff. I do not do anything as hard as that with mine. But it is falling apart. I liked My mahindra untill it started to fall apart. Overheats from day one. Every body on this board acts like a bunch of saints. They are never hard on there tractor. None of you all have never put your tractor pass the recomended use. Mine does not even get close to the recomended use. so NO! The operator is not the one that sucks MR. MUD. It is my 2615 HST that sucks. I am looking at another tractor to do 15 acres plus. Any sugestions would be fine. Yes there are lemons out there. And I feel my 2615 is a lemon. Things do not fall apart in 3 days.
/ Mahindra overheating #64
Out of your own mouth you are an abuser of equipment, and have reaped what you have sown. My 2625 HST is nearing 275 hours, has cut grass and brush in excess of 6', and only overheated once when the chaff built up before I realized what was happening. Since then, I've never had a problem because I don't neglect my tractor.
You must treat equipment with love and respect. Something you have missed out on I guess.
/ Mahindra overheating #65
Than like I said. I must have a lemon. Apparently you did not go to bills website thaT sold me the tractor. This tractor is good for 10 acxres plus. Has not even got near that. So how am I abusing it. I tried it and that is when I posted I am hard on it. Because I have realized this machine will not do what it says. That is not abusing equipment. Only if you keep trying to do it. My tractor from day one has not been able to cut grass even 2 feet tall without over heating. So apparently it is my fault the axle fell off from day 3 and it is my fault that Mahindra did not put a battery tie down that crashed through my front end. Abusing and being hard is 2 different things. I`m glad you have a good machine. And it treats you fine.
/ Mahindra overheating #66
Thinking about going round and round here. I finally come to a decision. I will offer any one that lives in the san antonio area to come and pick up my machine and use it for 6 weeks that post on this board. And I am even going to change the oil first. Take radiator out and clean and than grease all machine fittings real good. Lets stop this bull crap and I am willing to put my words where my mouth is. And if any one here uses my machine and does not overheat within several acres and does not break down. I will come back to this board and apologize. Any Takers. Email me and I will give you my number and we will talk about this.
/ Mahindra overheating #68
Bolts coming loose = Try Loctite, get a good heavy strength just remember to heat it if you ever need to take it off. I believe it's green that was designed specifically for Caterpillar.
Overheating = Try taking the radiator out and washing it on the floor, after that hold it up to light to make sure you've gotten everything out of it. You may need a radiator comb as you may have lots of bent fins. Make sure it is refilled with atleast a 50/50 mixture of antifreeze. Leave cap off with it running to make sure thermostat opens and it's full. Could it be thermostat is stuck or missing? Circulation is key. Replace cap. Put clean screen in front of radiator. Try running it in the grass with side panels on . If it still overheats try without them. If it still overheats check head gaskets, oil and antifreeze for contamination from each other.
I've had a 6000 for 5 years now and the only time it overheated was with the radiator screen full of debris. Tractor shouldn't run hot unless it's dirty or there is internal damage to the engine.
/ Mahindra overheating #69
Well after several weeks of posting the board is finally getting back on track Thanks jwcinpk for the input and help. If the head is warp or the head gasket is damaged. Will it cause the engine to get hot. The water is being used up and I do not know where it is going. I do not see it leaking or do I see it burning white smoke from the exhaust. If I thought the gead gasket was bad. I would of changed it already. I might try that but want some input. This has happened from day one on the water. As for the Loctite. Bill told the mechanics several times. Put Loctite on those axle bolts. Well it seems it is holding up right now. Just has the leak in the new axle assembly though. I have thought about running it wothout the side covers but I figured debris would get in there worse. I am going to try that also. I am opened to all sugestions. Thanks again jwcinpk
/ Mahindra overheating #70
jleal said:
Yes I have ran over car doors, bikes and all kind of stuff. Running over them and seeing them after you cut the grass. I did not say I was cutting the car doors and bikes. I always run a very high run first on lots and use the front end loader to scoop what I find out of the way. Am I doing something wrong.
YIKES!
yes, you need to walk over each lot before cutting if you have major pieces of debris like car doors and bikes.
there is a difference between use and abuse.
/ Mahindra overheating #71
jleal said:
That is ashame this machine can not even handle a quadraplegic.
A quadrplegic fixed it and it lasted 7 months. Took it back with same problem.
jleal said:
When I grow up. I want to be just like you UncleBuck
jleal said:
I am sorry for the typo error.You all are right. I personally myself would like to see a quad do that. I am paraplegic.
Unclebuck I know you been folowing my story around. Can I ask you what you use your tractor for. Are you a farmer or go out and do grass cutting jobs.
this machine can not even handle a quadraplegic. A quadrplegic fixed it and it
A typo error twice in the same post on the same word, Have you looked at the keyboard lately, Q and P are on opposite sides of the keyboard,
how about more likely its a LIE, until you get exposed, then its a error.
How about you are a a disgrace for USING peoples disabilities to try and get sympathy and credibility for your phony posts.
Can anyone tell me what tractor CAN handle a Quad/ para plegic
I use my tractor to run over LIARS and PHONIES, especially when they get caught, in my fields, thats why when you said in one of your previous lies, oh excuse me, posts that you run over dead bodies in the lots you cut , it caught my attention :D
Something tells me that day (grow up)will never come,
OH, is that your mommy in the background telling little jimmie to get off the net, :cool:
/ Mahindra overheating #72
This post is for the MODERATORS,
DO YOU BAN PEOPLE FOR LYING
Do you close threads after there is nothing of value to be added
How long would this thread have lasted if it was in the big 3 forums
AS for me , this thread is closed, with or without action by the moderators
/ Mahindra overheating #73
Agree.
/ Mahindra overheating #74
I also agree.....someone please close this thread and put it to bed....we keep going over the same old thing and no end in sight!!!!
/ Mahindra overheating #75
I must admit that SOME of the info he has posted in here is at least partially true. I have personally talked to the people he named at the dealer many times. The issue I have is that there is NO way a person would typo a disability. I HAVE heard of dealers fitting tractors with special controls for paraplegics and have even seen pictures of such, but THAT is never mentioned here. I would suggest a dealer call his dealer and verify what you can.
/ Mahindra overheating #76
Jeremy,
Even if SOME of the info is partially true, it stands to reason that his tractor problems would most likely be due to the following statements that "HE" made:
"I cut grass sometimes running constantly in 6 inches of water."
"Now I have been told I can break a steal marble when I was growing up."
(I'm positive he means steel)
"But like I said I use this machine hard. Very Very Hard. It does the job."
"My problem I should of purchased a little bit bigger machine."
"I guess I am going to go out and buy a bigger mahindra to cut the 15 plus acres lots I do. 2615 handles it but little hard. I mean grass that is 15 feet and higher and this is no lie."
Another statement was "Mahindra Sucks".Not just his Mahindra, but Mahindra the company sucks. I know for a fact that is not true. I have absolutely no sympathy for a liar nor any sympathy for someone who abuses their tractor then complains because it didn't hold up to the abuse. I agree with the above posters to CLOSE this thread as it is getting increasingly useless.
/ Mahindra overheating #77
I would rather this thread stay open. The only threads I prefer to close are the ones with constant, " I'm right, you're wrong" arguements. This one is easy, discontinue the discussion with this particular individual. It's quite obvious he hasn't been completely truthfull and he has also been insulting. When threads are locked, I always wonder what part of the discussion I missed, was something deleted. This individuals comments stand on their own and are easy to see through.
Either way, I won't lose any sleep over it, though. :)
/ Mahindra overheating #78
If you have a cracked head or a leaking head gasket generally you see cross contamination. Oil in the water or water in the oil. Sometimes not. If the water is leaving it's going somewhere. Is it boiling out the overflow? Absolutely it will cause overheating! Have you verified that 1) you have a thermostat and 2) it is opening? Is the radiator holding pressure? Head gasket replacement is quite a job. Sure you're up to that by yourself? That would be the last thing I'd do. After almost everything else. If you end up going there be sure to have the head checked.
/ Mahindra overheating #79
D#$% you would feel bad if this guy checked out!
/ Mahindra overheating #80
shvl73 said:
I would rather this thread stay open. The only threads I prefer to close are the ones with constant, " I'm right, you're wrong" arguements. This one is easy, discontinue the discussion with this particular individual. It's quite obvious he hasn't been completely truthfull and he has also been insulting. Where have I beeN insulting. Is it because I called Mahindra and there reps told me to take it up with bills tractor. So I said Mahindra Reps Suck. if a warranty is not going to be honored on something that has broken becauase of there fault than My Mahindra Sucks. As for the overheating of mahindra. Go to search in the discusion link and type overheating. It only comes up with Mahndra Overheating. Not any other tractor. As for being Disabled. Yes I am handicap in a wheelchair. Everybody makes typo errors. And yes there is a difference from use and abuse and there is a difference from using hard and abuse. Unclebuck stated he used his tractor hard. But it is alright for him to insult me. And its allright for him to use his tractor hard. The only insulting I have done is against mahindra and no persons. You all are the ones insulting me. Read all the post from the start. Where have I insulted someone. And yes call the dealer to make sure about my front axle wheel falling off. Front axles do not fall off from day 3. If that was the case there would be lots of dead people in this world when there wheel falls off on the highway. Why close the board. Is the moderator a Mahindra tractor dealer and the truth is bad for business. LOTS OF MAHINDRAS OVERHEAT OR THEY WOULD NOT HAVE A DISCUSSION BOARD ON IT.When threads are locked, I always wonder what part of the discussion I missed, was something deleted. This individuals comments stand on their own and are easy to see through.
And I am going to keep posting when someone comes and insults me or calls me a liar. I made an offer. I have a tractor here if anyone wants to look it over. Or If any one here that post to this board and in this area. I will go and cut grass with you free of charge so you can tell me what I am doing wrong. Than you can come back and tell it how it is. Like I said. Lets stop the insulting and move to reality here. Please someone call the dealer and verify the wheel problem and the battery problem. And how does an hour meter go out. The last time this machine was in the shop I told them to fix the hour meter. They did not. I told them about the seal leaking on the new axle and I did not hear. Bring it back. So how did I make a new axle seal leak. Now its my turn to insult. What kind of person would think I had something to do with that when the seal leaked from moving about 10 yards of dirt. A machine is not suppose to do that This is bumper to bumper warranty. If they would of tooken care of business. I would not being posting here. So please call bills and verify my story. This is really getting iritating when something keeps breaking especially when it started from day 3 of being new.
Status
