Comparison Mahindra or Kioti?
   / Mahindra or Kioti? #1
Hummer H1
Mid-Atlantic
JD's
I want a heavy tractor(for good traction), powerful, 50hp or so, 4wd with FEL. I will be moving snow with FEL and rear blade, maintaining a gravel road (about half mile), FEL work, using a rotary cutter, etc...
I want to try either a Mahindra or a Kioti. I have never owned either brand but I have heard good things about both. I would like a comfortable operators station (no cab), I am 6'5". I do my own regular maintenance. I have dealers for both brands close enough.
Which one should I buy and what model? Thanks:)
   / Mahindra or Kioti? #2
They are both great tractors. I would take a good hard look at both. I would probably get the one that fit me the best. Sit in the seat of each and get a feel for all of the controls. How they are placed and if that fits you. Double check the specs of each one, I would guess that they are pretty close. Mahindra just came out with a 5035, it looks to be a very nice machine, but then I am a little partial, I have 2 Mahindras. Double check what options are available, they are usually less money if purchased at the same time as the tractor. So if you think that there is even a chance that you might need or want any of those options, best to get them with the tractor purchase. A lot of times, you can also get great deals on implements at this time also.
Do a lot of research, ask a lot of questions.
Good luck
   / Mahindra or Kioti? #3
Maybe you could get the dealers to let you bring them to your house and run 'em for a few hrs to see what you think.
These are both well respected names and you prolly wouldn't go wrong either way.
   / Mahindra or Kioti? #5
When I looked in the 60-70 range and ended up buying the 7520, I dont remember why I eliminated Kioti. I think it was either less hydraulic delivery or smaller front tires or no 2 speed pto. The 7520 had everthing and nobody else in the price range did.
Happy shopping!
larry
2021 JCB 3TS 8T SKID LOADER (A51242)
2021 JCB 3TS 8T...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2008 FORD F-250XL SUPER DUTY EXT CAB TRUCK (A51243)
2008 FORD F-250XL...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
