Mahindra Max28XL Starting Problem
   / Mahindra Max28XL Starting Problem #11
I don't know of any 28s that are under 2yrs old so most likely out of the bumper to bumper warranty... its an easy fix to do yourself though... just be sure you unplug with wires and twist with the solenoid when you spin it off and also when you put the new one on... makes life easier to unbolt the coolant reservoir
   / Mahindra Max28XL Starting Problem #12
I am having a little different problem. My tractor runs fine if the RPM's are not maxed out, Once I open the throttle all the way after 10-20 mins the tractor shuts off. It will start up normally after that, but will shut off again if I open the throttle all the way. Any ideas? I was not sure if the fluid solenoid would cause this.
Thank you
   / Mahindra Max28XL Starting Problem #13
Thank you
Welcome to TBN. Your best bet is to open your own thread stating your particular issue, even if it's MAX related. You'll get more replies, and won't be hijacking the other member's thread.
   / Mahindra Max28XL Starting Problem #14
Thank you
When is the last time you changed the fuel filter and air filter
   / Mahindra Max28XL Starting Problem #15
Thank you, I am new.
   / Mahindra Max28XL Starting Problem #16
Hi everyone,
Can someone confirm that this is a good fuel shutoff solenoid for the Max28XL it痴 a far cry
Less expensive ??
I got this one and it worked out fine.
   / Mahindra Max28XL Starting Problem #18
Just a fair warning>> folks that are buying those off the web are experiencing that SOME of the plugs are different..
You may have to cut & solder?? But after all is said & done, the solenoid works as it should..
   / Mahindra Max28XL Starting Problem #19
The only issue I've ever had with mine. Turns over fine. Just wont start. The wire that connects to the rail on top look like a blade type. Unplug it and plug it back on. Usually starts after that. Now it wont fire at all.
   / Mahindra Max28XL Starting Problem #20
Once it ever starts, runs great. Seems like its once few months. Could it be the fuel shut off?
2017 Hino 268 20ft Flatbed Truck (A52377)
2017 Hino 268 20ft...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
2014 Ford Escape (A50323)
2014 Ford Escape...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
MISC WRENCHES (A53843)
1267 (A50490)
1267 (A50490)
