Mahindra Max24 HST FEL lowering speed
   / Mahindra Max24 HST FEL lowering speed #1
kas64
Kawasaki Mule 610 , Mahindra Max24
This might have been answered elsewhere in the forum and if so, I apologize in advance.
My question is, on this unit, is it possible, or is there a way from the factory, to slow the FEL bucket drop speed? Similar to the 3 point hitch flow control underneath the seat?
If there is, I've been unable locate it.
When handling a load, I've tried feathering the joystick but, it seems to fall pretty quickly once it hits the 'break over' point. Now it doesn't fall all the way to the ground but, drops pretty drastically.
Any help would be appreciated.
   / Mahindra Max24 HST FEL lowering speed #2
Try changing engine speed. you are running high rpm go to idle speed to see if that helps
or as crazy as it sounds speed rpms up to see if that helps.
On some cranes for example I would keep rpms up to have more soft control of the load line
If not it takes practice
   / Mahindra Max24 HST FEL lowering speed #3
Kas
Unfortunate reality is that some valves have little to no metering to allow slow precise (feathering) movements. The original valve on my Branson had none so I replaced the valve.
You can put a flow control or orifice in the line from cylinder to the valve with understanding it will work differently with loaded bucket vs empty.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
2016 Doyle 10T Tender (A56436)
2016 Doyle 10T...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
ADS Bulk Seed Buggy (A59814)
ADS Bulk Seed...
