Mahindra Max 28xl PTO
   / Mahindra Max 28xl PTO #1
dclynch
kawkawlin,mi
Rhino International
When tilling the garden my PTO would randomly stop I didn’t hit anything and the garden has been tilled many times over the years. If I push the clutch in it would start back up again. It’s never done this in all the years I’ve had the tractor
Just a bump. Was hoping to get a response
   / Mahindra Max 28xl PTO #3
Are you sure it is the PTO vs a clutch on the tiller. My tiller clutches out sometimes underload (hitting a big rock or large root).
PTO quiting, to me that would be split the tractor and repair.???
   / Mahindra Max 28xl PTO #4
If the tiller has an over running clutch on it, it's possibly slipping or the plates are shot and need replaced.
It’s definitely the pto on the tractor that stopped. If I push the clutch in and let it out it restarts. I have some tilling to do this weekend so I will check again. I also adjusted the slip clutch on the tiller and verified that is working
If it's the pto clutch that has failed, that is a big ouch.
That’s what I’m afraid of going to call a dealer Monday to see what it will cost to fix
Ok can anyone tell me if using it with the pto stop working occasionally am i doing any damage using the tractor? I can’t get the tractor in anywhere for at least a month. I need to get the garden in. I’m trying to find a service manual and may attempt the repair myself
   / Mahindra Max 28xl PTO #9
your prolly putting a ton of clutch material in the hydro fluid at a minimum, or metal if the clutch is gone.
   / Mahindra Max 28xl PTO #10
If this is a mechanical clutch Have you verified the free play adjustment on the tractor clutch pedal?
If mechanical it is probably a dry clutch and would not contaminate the HST system.
City of Denton (PM14103): VIN #: JK1AFEB17EB526623 (A55973)
City of Denton...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
11'9" CONTAINER (A52706)
11'9" CONTAINER...
2017 JCB 510.56 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2017 JCB 510.56...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
