Mahindra Max 28... Not Starting !
   / Mahindra Max 28... Not Starting ! #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
[h=2]
Mahindra Max 28... Not Starting ![/h]
Hello to all the people reading my post ! It has been a while but the SoCal remodel took far longer than expected and in a way is still on-going, barn wiring, Forge Setup, and the new compressor system !
My Max 28 took a fit and decided not to start.
It has been giving me trouble starting for a while, if I bounce on the seat it would start... Seat Safety Switch right, that was my guess.
I jumper the Seat Switch out and the engine started but as soon as I let go of the key, from the start position, the engine stopped running.
Any suggestions ?
Thank you to all for your comments !​
   / Mahindra Max 28... Not Starting ! #2
Fuel solenoid. Know issue with that model. :thumbsup:
Is there a step by step on removal of the Fuel Solenoid ?
   / Mahindra Max 28... Not Starting ! #4
Step x step.. seriously?? It screws in & out.. just measure it before removal..
Just google>> mahinda max 28 injection pump.. theres videos & pictures..
Yes seriously ! I like to know what to expect !
Thanks, I have done nothing to this tractor since I purchased it four years ago... I'll give it that !
I didn't know if there were internal connections I needed to worry about, or as you said measure the position... !
I have worked on vehicles, Car and Trucks, but never a diesel and or tractor, the same yes but knowing what tot expect is a help !
Thanks for taking time to post !
   / Mahindra Max 28... Not Starting ! #6
I致e previously posted the procedure from the manual. Look up my previous posts. I壇 resend it but stuck in a plane on the tarmac
   / Mahindra Max 28... Not Starting ! #7
U haven't touched it in 4 years?? maybe that's why it isn't starting.LOL.. Just kidding.
The sol. is to the left of the injection pump.. looks like a small soda can.. it screws into the block..
For some unknown reason they made extra long threads on it w/ a large lock nut.. just measure it before removing..
The "book" gives a long, drawn-out explaination on how to set it..
I do it the easy way.. I've done it 100x & it works just fine.. probably better & more accurate than the "book"..
With the solenoid backed out & the engine running.. screw the sol. IN until the engine slows down & shuts off.. tighten the lock nut.. plug it back in.
NOW.. try it w/ the key switch.. start the engine, shut it off.. if it struggles to shut off or has a "run-on" condition.. screw it IN some more.. about 1/2- full turn.. retest..
   / Mahindra Max 28... Not Starting ! #8
I had a shuttle shift and had similar issues. I used to have to giggle the gear selector and the speed selector to make sure it was in neutral.
2019 RAM 3500 (A52472)
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2014 D&P WELDING 16FT PRESSURE WASH TRAILER (A52472)
2014 D&P WELDING...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2000 FREIGHTLINER CC CONVENTIONAL(INOPERABLE) (A52472)
2000 FREIGHTLINER...
