Mahindra Max 26XLT or Kioti CT2510
   / Mahindra Max 26XLT or Kioti CT2510 #21
TYM would probably be the Korean company he couldn't think of. They make most of Mahindra's smaller tractors.
   / Mahindra Max 26XLT or Kioti CT2510 #22
Re: Mahindra Max 26XLT or Kioti CK2510
Manufacturers loader lift numbers don’t really tell the whole story. The higher a loader lifts, the less capacity it has at full height. The geometry of the loader lift cylinders dictates how high it will lift and how strong it is when it’s at ground level. Lower lift heights usually mean more breakout capacity. If you need the height to to stack bales or something, then get the one with the highest lift, if not the lower lift loader will probably lift more weight during normal use. I bet both loaders use the same diameter cylinders,o one isn’t really stronger than the other. Manufacturers just play up the attributes with the highest numbers.
   / Mahindra Max 26XLT or Kioti CT2510 #23
Of course just because the loader is strong enough to lift something doesn't mean that you can or should. The loader on the Max 26 XLT is rated to lift about 75% of the tractor's weight. You might manage to get that off the ground if sitting level and well ballasted, but moving it anywhere could cause excessive seat suction.
Both of those tractors are very capable for their size. I don't think the OP would find either lacking.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A49461)
2007 Bomag...
