Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #1
Tmanning03
Mahindra MAX 26XL
2014 Mahindra Max 26XL bucket will not lift at all. This is the only function on the front loader hydraulics that will not work.
I have bled lines, refilled, maxed out, changed lines, etc etc. I assume it has to do with the Besko HDMO3/2 (drawing of valve attached) spool valve but I cannot find any diagrams on the spool valve or any replacement parts. HELP!!! I have removed the floating spool and do not see any internal issues but im by all means no hydraulic mechanic, should there be some O rings in there?
It could be easier / cheaper to replace Besko Control Valve HDMO3/2 with something like Prince so I could get parts but that could be expensive and I would have no clue what model would compare.
Thanks in advance!!
Tucker
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #2
Does your joystick have cables? Have you tried reversing the lift and dump hoses on the loader? If the bucket then lifts and will not dump then it could be a broken cable. They can rust out due to moisture in the sheath.
I have reversed the hoses and the bucket does not dump. Hoses were switched and no change. This is why I assume it痴 in the hydraulic control and is more than likely to do with the spool valve i.e. internal 登 rings or ??
I really appreciate the help and response though!
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #4
Thanks in advance!!
Tucker
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #5
The Besko Control valve on my Mahindra 4550 4wd 4L loader busted the cover cap off the Spool regeneration got a new cover on it and then it busted the cover off the Spool Floating side. Seems something is wrong inside the valve. I have contacted several so called Equipment dealerships for some help and get the same thing we will be in contact with you in 24 hrs. i have yet to talk with anyone i want name them but i know who i can't depend on and for sure want buy anything there. Now to my question can you tell me a brand and model # that i can get to replace the Besko valve. It's crazy what Mahindra wants you to pay for one of those. i have only 160 hrs. on the tractor/loaded. Thanks in advance for your help, Stan Brantley
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #6
Thanks in advance!!
Tucker
I'm going to try ebay 2 Spool 21GPM Hydraulic Directional Control Valve for Tractor Loader w/Joystick | eBay
   / Mahindra Max 26 XL Hydraulic Besko Spool Valve Issues Bucket wont lift #7
Did it work?
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2018 John Deere 460E Articulated Dump Truck (A53473)
2018 John Deere...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
Loader bucket (A53117)
Lincoln Electric Welding Machine (A53117)
Lincoln Electric...
Miscellaneous electrical stands (A53117)
Miscellaneous...
