Mahindra Max 22 Won't turn over
   / Mahindra Max 22 Won't turn over #11
I spent quite a while going over the electrical drawings last night and came up with a few ideas to check...mice wasn't one of them. However, I do seem to get some unwelcome visitors every fall and winter so I'll have to add that to the list. My experience in life is that anything that moves is likely to fail at some point. Do you think the timer or relays could be my problem? Thanks for the suggestion. I see a lot of voltage checks in my future.
Lift t the seat and find the safety cut off switch.
By pass the switch with a jumper after unplugging the connection.
See if it starts. Not meaning to insult but did you also check fuses?
I do not think you have a relay problem if they are engaging by your description.
Remove and clean all high current cable connections, including on the starter itself. A high resistance connection will cause those symptoms.
Another possibility is cumulative resistance in the safety switches, ignition switch, and starter solenoid. Get a voltage reading at the solenoid (while in the crank position) to see if the voltage is adequate to fully engaged the solenoid. A work around typically done for low voltage on the trigger wire is to add a relay that provides the solenoid with 12v directly from the battery. I installed several relay kits on my zero turns to fix "click click" starting problems.
Thanks for the suggestions. I'm not real diesel expert...far from it but, I do have a lot of electrical experience and what I'm seeing leads me to think there is a problem when there is a high current demand. I've given serious thought to bypassing all of the safety interlocks just to eliminate the possibility of one acting up since they are in series. I've also considered using a heavy cable from the battery directly to the starter to see if it cranks. I'll try your suggestions over the next few days. Thanks again.
I'm going to bypass all the safety switches just to eliminate the possibility one is the culprit. I know in the past I've had to mess with the pto lever to get it to turn over but in that case it was all or nothing, I would turn the key and it would start or it would do nothing until I repositioned the pto lever. This problem is different, it seems to occur when there is a high current demand. All fuses are good, no insult taken, sometimes one can completely overlook the obvious so everything is on the table. Thanks for the suggestions.
   / Mahindra Max 22 Won't turn over #14
The seat safety switch is a known culprit.
I’ve had to fix 3 of these in the field over the past 6 yrs.
l would start there first because it’s so easy.
Unplug the connection, insert jumper wire from A to B female so as to create continuity and start her up.
   / Mahindra Max 22 Won't turn over #15
Two possibilities I can suggest. On my tractor the negative cable looked great but after unbolting it from the frame I found corrosion from rodent urine causing a bad connection. Then a few years later the starter would click but not turn. It was the contact inside the solenoid that was bad.
Eric
Thanks for the replies. Still working the problem, trying to be methodical starting at the ignition switch and safety switches and working forward. When I removed the plastic cover (dashboard? )containing the ignition switch, odometer etc, I was amazed at how much dirt had accumulated there, in some areas it was a half inch thick and more. I would not be at all surprised if the connectors in this area were corroded. I will post again after next troubleshooting session.
One new question though. According to the wiring diagram, when the key is placed in ON position it should energize the load relay. It is doing that but its not like on or off. When it's on, the load relay chatters. My experience with relays is on is on, no chatter, but when I swapped the load relay with the safety relay it does the same thing. Any thoughts as to what is causing the chatter?
   / Mahindra Max 22 Won't turn over #18
i would check the voltage at the relay, its prolly low.
if it is, I have read and have not experienced it, but there is a large wire bundle on the right side near the throttle in the dash, that is crimped together, this apparently corrodes and can cause large voltage loss.
   / Mahindra Max 22 Won't turn over #19
It is more than likely chattering due to low voltage, check voltage at the relay, check the positive battery cable and if i remember correctly there is a connection off the positive cable to some smaller wires, look for dirty connection there.
   / Mahindra Max 22 Won't turn over #20
It chatters. They all do on most Mahindras
22ft. T/A Utility Trailer (A56858)
22ft. T/A Utility...
SD Lanch SDLGC80 Electric Golf Cart (A57149)
SD Lanch SDLGC80...
Mower King SSRC72 72" Brush Cutter (A57149)
Mower King SSRC72...
LINCOLN ELECTRIC IDEALERARC DC-600 WELDER (A58376)
LINCOLN ELECTRIC...
2025 Future 750 Remote Control Crawler Mower (A56859)
2025 Future 750...
Kubota Diesel Tractor (A57453)
Kubota Diesel...
