Mahindra low coolant/overheat shut off?
   / Mahindra low coolant/overheat shut off? #1
whitravis
3215 Mahendra
3215 radiator ran dry while I left it running to purge air. New tractor to me but obviously poorly maintained.
Small puddle of antifreeze on the floor and tractor had shut down.
Now it's no crank no start. Main fuse blows immediately when key is turned.
Is there a low coolant switch or overheat switch.causing fuse to blow? Would be so nice if refilling the radiator would solve this, but I doubt it.
I'll check to see if engine is locked up (unrelated to fuse.)
I've pulled all three other fuses and main one still blows.
