Mahindra Hydro Fluid
/ Mahindra Hydro Fluid #1
dadreier
Lewisberry, PA
Mahindra 2817H
Yesterday I went to purchase another bucket of hydro fluid for my Max 28 and found out that what I wanted was no longer carried at the (close by) store.
I'm sure I can find another source, but I'd rather not waste any more gasoline/time than is needed for this one purchase.
Back when I first got the machine, the dealer sold me a generic "universal" fluid which was inexpensive and seemed to work fine. I figured that if the dealer gave me this, there wouldn't be any question if a warranty issue came up. Since then, however, I've been able to find locally something from Mahindra's (rather sparse) listing of recommended fluids. Now I've got to start looking again. Before I do, however, I thought I'd see what others are using.
What hydro fluid do you use in your (especially Mitsubishi-built) Mahindras?
/ Mahindra Hydro Fluid #2
I use the Mahindra oil from my dealer for my MAX 28.
/ Mahindra Hydro Fluid #3
for my 100 hour I went with Amalie Ultra Trac 245. Its multi grade, very good in cold climate, transmission noise is down a bit as well. Heres a link to the data sheet. Amalie Oil Co.
/ Mahindra Hydro Fluid #4
I only use Shell Donax, which has been changed to something (Spirax, I think) now. Shell Spirax gear oil also.
hugs, Brandi
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
3pt Counter Weight (A64127)
3pt Counter Weight...
429872 (A61166)
429872 (A61166)
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
