Loader Mahindra hydraulic sensitivity
   / Mahindra hydraulic sensitivity #11
mahpop
Again I hope no offense was taken because I did'nt mean any...I was just curious..Hat's off to you for watching out for your neighbor's,as that is what a good neighbor is supposed to do.You did'nt mention the year or model of the machines.My 4530 with the 245 loader is is anything but sensitive..In my case I want to speed operation up..
Regard's
Sean..
   / Mahindra hydraulic sensitivity #12
mahpop,
Does this sensitivity get worse when lowering with a load in the bucket? If yes then it is definitely pointing towards a control valve with limited or poor metering characteristics. Will a dealer do something about this, probably depends on the dealer and if the loader was installed at the dealership etc... They may try the "band aid" of installing flow controls or orifices to hide the problem Vs fix the problem.
For reference I believe the valve I removed from my Branson was a Nimco and it had no metering.
What size tractors are these?
   / Mahindra hydraulic sensitivity #13
If the valve has any metering capability at all, lengthening the joystick (maybe try twice as long) is something simple and cheap that will give you a bit more control.
seaneastok
No offense taken. I should have mentioned in the original post that we use a Long tractor for the heavy lifting.The Mahindra is for the small jobs including brush hog work around both places.
oldnslo
The sensitivity is there at all times. Both tractors are 4530's. I'm new to the Mahindra, I'm a John Deere guy so I'm kind of feeling my way with this machine. I've never run into this problem with the Cat dozers or Deere backhoes I run.
D Miller
Interesting possibility lengthening the joystick. Thanks for the heads up, I'll give it a try.
   / Mahindra hydraulic sensitivity #17
mahpop
just curious year of the machine's my 2012 has the kmf 245 loader on it and it is anything but sensitive...I'm talking a fully loaded bucket in quick dump is still slow....Mine's to slow....Your neighbors is to fast...Wanna trade? lol...:laughing:
2016 Club Car Carryall 710 Electric Utility Cart (A55851)
2016 Club Car...
2015 Freightliner Sprinter 3500 Cargo Van (A55852)
2015 Freightliner...
PENDING SELLER CONFIRMATIONS (A56138)
PENDING SELLER...
Honda EM4000SX Generator (A55851)
Honda EM4000SX...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
