Mahindra Fuel Injection Pump
   / Mahindra Fuel Injection Pump #1
vangelistree
putney, Vermont
mahindra 7520 4wd
So here is my issue, I can not remove/disconnect the FIP from the FIP gear. I have all the hoses off, bolts that go into housing are off, and the FIP main nut and lock washer are off. Got it about a 1/8 of an inch out, the issue seems to be that it will not let go of the gear. in the instructions it says i need a special tool to remove it... and doesn't tell me at all what that is. I have removed several other FIP's. The FIP is a Bosch pump, VE4/12F1150R1038-1, the tractor it is on is a '20' series 4wd 7520 Mahindra. Any incite into this vexing situation will be greatly appreciated.
   / Mahindra Fuel Injection Pump #2
If you'll look closely at the gear, it has bolt holes in it..
Those holes are meant for a puller.. the pump drive shaft is tapered & "stuck" on the gear..
IF I recall, the drive shaft is NOT keyed & its a "tapered fit".. which means the ONLY THING holding the DS & gear together IS the tight fit..
I may be wrong but either way, its stuck on the pump d.shaft & you need a puller..
LOOK for a key.. look for a slot cut in the gear behind the nut & washer.. no slot=no key..& you better hope to god you timed it correctly..
I'm in the injection pump "biz".. & have bought several of those pump pullers.. the latest one I bought was from Xtreme Diesel online for around 35-40.00.. & its better than the snap--on 1 I have..which cost 88.00..
   / Mahindra Fuel Injection Pump #3
OH WAIT.. I just remembered, the last Mahindra I did, I wasn't able to use THAT {XD} puller.. the holes were too close..
I ended up using a flywheel puller for a lawn mower.. I also bought THAT online.. I don't remember where, but it has about 4-6-8 different hole positions that you can use for a lot of different screw configuration..
& yes, THAT PUMP WAS keyed & had a timing line on the outside of the pump housing for final timing..
BUT.. the inside of the pump had imploded & was VERY expensive to fix..
IF you would like to contact me, feel free.. I can probably save you 100.'s vs your local repair shop..
   / Mahindra Fuel Injection Pump #4
Afternoon,
I just bought a 2006 mahindra 5500. The mechanic says i'll need to have the injector cleaned or rebuilt. Any tips on if cleaning is advisable?
   / Mahindra Fuel Injection Pump #5
The injectors have to be taken apart and retorqued IN A SPECIAL JIG that holds the insides from turning..
There are tiny alignment pins inside.. if u simply try to unscrew it, u break the pins and ur left with buying another injector..(cuz u can’t fix the broken pins)
On top of all THAT.. u need a pop tester to check the opening pressure, spray pattern and leakage..
   / Mahindra Fuel Injection Pump #6
BTW.. I have that jig..
I’ll send u a prvt msg.
   / Mahindra Fuel Injection Pump #7
Holloway Bear Cat Having problems getting pump shaft to move out of gear don't know how much pressure I can put on it to remove pump it's on a Mahandra 2011 5525 tractor any help would be appreciated.
   / Mahindra Fuel Injection Pump #8
I take it u removed the nut and washer from the drive shaft.??
Idk how I’m supposed to explain how tight u need to have the puller.??
I remove the nuts/bolts holding the pump to the block and just screw them back on to keep the pump from taking off when it does break loose..
I’ve also used a wedge or two between the pump and block to “help” the puller..
Good luck
   / Mahindra Fuel Injection Pump #9
Good luck
Got nut and washer off. What I was getting at about the pressure on pump shaft and gear before breaking something with the puller. I don't have a breakdown of engine don't know what I'm up against. I have got fip out away from housing about 1\8 inch but no more with puller really torked down does this sound right ? Thanks I try the wedges too. No help from our Mahandra dealer here !
   / Mahindra Fuel Injection Pump #10
I’ve only removed a handful of pumps from Mahindra tractors.. so I’m no expert with the removal parts of the equation.. & w/o pictures or physically being there, I’m at a loss..
UNUSED 16" AUGER (A51248)
UNUSED 16" AUGER...
(INOP) EZ GO WORKHORSE GOLF CART (A51247)
(INOP) EZ GO...
UNUSED FUTURE HYD 16" AUGER (A51248)
UNUSED FUTURE HYD...
2019 KOMATSU D51PXi-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
