Mahindra engine
/ Mahindra engine #1
cdover73
Greensburg, Louisiana
2006 Mahindra 4530
I have a 4530 and I have to ask. If Mahindra makes the engines for these tractors, why do they look and sound so much like a Perkins?
/ Mahindra engine #2
I know I read it somewhere and asked the local dealer a while back when I went to look at the 4530. He said the engine was a Perkins/Shibaura 3 cylinder, but I could never find out exactly which engine it was. It would make sense since I believe a Mahindra assembly plant and a Perkins plant are in Georgia, but that may just be a coincidence.
I believe the smaller Mahindras use the Daedong engine.
/ Mahindra engine #3
Gentlemen, the '00 series engines (and I assume the 4530 as well as the 7520, etc) are completely built by Mahindra in India. The parent engine (00 series 3 and 4 cyl) were specifically designed by AVL in Austria for Mahindra. AVL has been building diesels for quite some time (I'm thinkin' pre WWII). It is entirely possible that Perkins (also Euro) copied some of the AVL designs way back when.....I'm just hoping that the Mahindra engines are as good as their designs.
/ Mahindra engine #6
Well thanks so much for this info I have a 2021 Mahindra 2638 tractor. The plate that is on tractor and the stamped in block numbers are below,
Plate on tractor
Agriculture tractor 2638NH
4 cycle diesel 37.4 HP/2400RPM
serial number=38HRR09621
TONG YANG MOOLSAN CO,LTD
The information stamped into the engine block are:
EB-01-18-2021
NMKK JDE0244
Would you know who makes this engine please its a 4 cylinder no turbo and its 37.4 HP. Please give me anything you may know i have looked quite a bit,Thanks Mike Buck
/ Mahindra engine #7
Tong Yang Moolsan (TYM) built tractor, just like my 2001 4110. Daedong engine - mine is an A200, 41 hp. Mine has well over 3200 hours on it and doesn't ever fail to start year 'round and doesn't use/leak a drop of oil.
/ Mahindra engine #8
Plate on tractor
EB-01-18-2021
NMKK JDE0244
It is my understanding that the 2538/2638 engines are in-house products:
Built in India and shipped to South Korea to be installed on the tractors there.
/ Mahindra engine #9
I just checked if Daedong made my exact HP/Cyl and here is what came back"
Yes, Daedong makes a 4-cylinder, 37.4 horsepower diesel engine:
  • Daedong diesel engines
    Daedong Industrial Co., Ltd. produces a range of diesel engines from 20–60 horsepower, including a 4-cylinder, 37.4 horsepower engine.
/ Mahindra engine #10
The info from tractor data .com says thet is a mahandra built engine with 166.7 ci do you have regin function on the engine ?
/ Mahindra engine #11
Mine has the dingdong engine.
/ Mahindra engine #14
/ Mahindra engine #15
I also have a xg3135 LS with the regin that is not to bad but I really like the mahindra no regin i don’t know if anyone else has a engine with no regin except Mahindra, i don’t know if love that feature hope it don't bite us in the but
/ Mahindra engine #17
More and more big names I thought were switching some of their tractors over. I thought I saw an article about some kubota's getting rid of it. But, looking online now I cannot find anything.
/ Mahindra engine #18
I dont have many hrs on it but good so far I really like-the tractor and no regin engine especially the cab with ac for summer here in Louisiana . At 88 in a few days my kids will probably get the most use out of it but i can play in comfort until then.
/ Mahindra engine #19
I ment to say years
/ Mahindra engine #20
Kukje engine in my eMax 22 bought in 2019. I have recently read that TYM bought Kukje. This is a great tractor.
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2014 BOBCAT T870 SKID STEER (A65053)
2014 BOBCAT T870...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
2019 MULTIQUIP TOWABLE GENERATOR (A63276)
2019 MULTIQUIP...
Walk behind Mower (A64194)
Walk behind Mower...
