Oil & Fuel Mahindra Diesel Engines
   / Mahindra Diesel Engines #1
bwc
Atlantic Canada
JD 455
New to Mahindra and cannot find out who makes their tractor engines, especially in the smaller models, 2015. Thanks
   / Mahindra Diesel Engines #2
the 2015's have Mitsubishi diesels in them
   / Mahindra Diesel Engines #3
That's right. And ALL the 15 series have Mitsubishi power, made in Japan. That is a primary reason I chose my specific tractor.
I believe most other Mahindra tractors have the Daedong diesel, made in S. Korea.
   / Mahindra Diesel Engines #4
Remember the 15's are not Mahindra at all except for the decal. They are Mitsubishi through and through...This is a good thing.
   / Mahindra Diesel Engines #6
those are only the 10 series......3510, 4110, 4510, 7010.
   / Mahindra Diesel Engines #7
carpetride said:
Who makes the 4530 engine?
I know that the 4500/5500/6000/6500 engines were designed by AVL (Austrian) and are built by Mahindra in India. I'm assuming that the 4530 uses the same as the 4500. Oh, by the way, the engines in the 00 series are about as robust as any I've ever seen on a tractor (,,,,,including the Perkins that's used in a number of tractors. Only issue I've heard of is in the 7520 (uses the 6000 engine with a turbo) which has the gear driving the hyd pump (the thread is below somewhere) in one case that failed. BobG in VA
   / Mahindra Diesel Engines #9
Keep in mind Mahindra corp is a huge marketing operation as well as a tractor manufacturer. Some models they build in their own plants, others are contracted for so that they can offer a broad product line. It's the same business model as Deere, who offer some 'Deere' models manufactured by Yanmar, etc.
I expect Mahindra to be a more significant player in the years ahead. Note the other thread discussing that Mahindra may buy Jaguar from Ford.
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
