Mahindra Battery Corrosion
   / Mahindra Battery Corrosion #1
jamesbuehner
Talent OR
Mahindra Max
Mahindra Max 28 XL hst is just over a year old - in the first months of operation there appeared significant corrosion at the positive post. And yesterday during routine maintenance, I was aghast at the spread of the corrosion from the post to the tie down "j" bolts. This is unacceptable. What could be causing the phenomenon in an otherwise very clean tractor?
   / Mahindra Battery Corrosion #2
Im having the same issue. I've read that there was a bad run is the exide batteries. Not sealed at the post. Other have gotten the batteries and cables replaced under warranty. I'm hoping to take mine in soon for the same. I have corrosion on the lower comers on the side panels as well.
   / Mahindra Battery Corrosion #3
yup, my dealer said it's a very common problem. I had the same problem after having it for about 4-5 months. I took mine apart, cleaned it all up and coated everything with grease last Fall.
So far so good.
New threads like this should be made in the Mahindra section.
   / Mahindra Battery Corrosion #4
Hi and welcome to the forum, James!
I am moving your thread over to the Mahindra section. Hopefully you'll find some answers there. :)
   / Mahindra Battery Corrosion #5
Sounds like the battery is leaking around the positive post.
   / Mahindra Battery Corrosion #6
Most machines don't have well thought out battery trays and hardware. They don't seem to care if your machine doesn't stay new very long! The paint in those areas never lasts long. I have modified brackets and bolts in those areas with epoxy filled heat shrink tubing and plastic or rubber under the battery. I like using those coated felt disks under the terminals as well.
   / Mahindra Battery Corrosion #7
Compare battery brands, see if they are from the same maker. I don't think the tractor itself would cause that problem. But stranger things have happened.
   / Mahindra Battery Corrosion #8
The Exide that came in my 4035 had some minor corrosion on the terminals when I bought it. It continually got worse at a pretty rapid pace. The battery died at the beginning of the year and I cleaned everything up real good and recoated things with some paint. Probably not as well as it was new, but good enough as long as the source of the corrosion were stopped, it would be fine. When shopping around for a replacement, I searched specs to get the heaviest battery I could. That turned out to be a NAPA battery. Since switching the battery the corrosion has not started again.
The bad batch of Exides mentioned above is a possibility...
   / Mahindra Battery Corrosion #9
Battery is part of general maintenance.. the ends need to be checked while doing your service then cleaned and coated if need be
   / Mahindra Battery Corrosion #10
After a couple of incidents of severe corrosion in the battery compartment, due to a leaking battery, I'd had enough! My solution was to spend the money on an OPTIMA REDTOP, sealed battery.
Motorcycle Battery | Truck Battery | REDTOPョ | OPTIMABATTERIES
The REDTOPョ high-performance AGM battery is the ultimate starting battery designed to deliver a powerful burst of ignition power for a reliable start-up every time, whether it's used as a truck battery, automotive battery, or for other applications. The REDTOP will outperform and outlast traditional batteries in demanding cranking/starting applications. With impressive high-power delivery and extreme resistance to the most common causes of battery failure, the REDTOP is ideal for trucks, SUVs, hot rods, street cars and other applications that require a spillproof starting battery. Its reputation as a truck battery or automotive battery is unsurpassed.
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2014 Chrysler Town and Country Van (A50324)
2014 Chrysler Town...
2016 JOHN DEERE 135G (A52472)
2016 JOHN DEERE...
