Mahindra backhoe
   / Mahindra backhoe #1
Gulfmp
Central ma
Kubota 2370-1, FEL, MMM, Box Scraper, 3Ph Snowblower
Can a 1500 series backhoe be used on a emax 25 hst?
What is the height of a emax 25 hst cab?
   / Mahindra backhoe #2
You should ask in the Mahindra section. Lots of info there.
   / Mahindra backhoe #3
Likely, not. eMax 25 calls for the 25B, backhoe. The 1500 series are for the Mitsubishi built tractors. eMax is TYM built, and too small for a 1500 hoe.
   / Mahindra backhoe #4
I have a 1538 hoe and don't think it would fit a small little emax. About the smallest it will fit is a 1533. You need a subframe for it and that determines which hoe will fit. Remember you also have all the hydraulic stuff and other fitment things to fret about too. For example the hydraulic filter on mine was impacted. Just look at the Mahindra site and get the model they recommend. I think the emax hoes include a seat but mine is a spin around for the tractor seat.
   / Mahindra backhoe #5
You would want to figure out who builds the backhoe and check with the actual maker. Companies like Woods, Bush Hog, etc build a hoe that will fit dozens or even hundreds of tractors.
   / Mahindra backhoe #6
KMW builds the 1500 backhoes. I don't know who makes hoes for the emax tractors, could be TYM, KMW or someone else.
   / Mahindra backhoe #8
Does Bradco still make the larger backhoes? Specifically the backhoe for the 3550?
   / Mahindra backhoe #9
1265 (A50490)
1265 (A50490)
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
Ranger Welder (A52377)
2006 Hummer H3 (A51694)
2006 Hummer H3...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
