Mahindra backhoe
/ Mahindra backhoe #1
Gulfmp
Member
Central ma
Kubota 2370-1, FEL, MMM, Box Scraper, 3Ph Snowblower
Can a 1500 series backhoe be used on a emax 25 hst?
What is the height of a emax 25 hst cab?
/ Mahindra backhoe #2
You should ask in the Mahindra section. Lots of info there.
/ Mahindra backhoe #3
Likely, not. eMax 25 calls for the 25B, backhoe. The 1500 series are for the Mitsubishi built tractors. eMax is TYM built, and too small for a 1500 hoe.
/ Mahindra backhoe #4
I have a 1538 hoe and don't think it would fit a small little emax. About the smallest it will fit is a 1533. You need a subframe for it and that determines which hoe will fit. Remember you also have all the hydraulic stuff and other fitment things to fret about too. For example the hydraulic filter on mine was impacted. Just look at the Mahindra site and get the model they recommend. I think the emax hoes include a seat but mine is a spin around for the tractor seat.
/ Mahindra backhoe #5
You would want to figure out who builds the backhoe and check with the actual maker. Companies like Woods, Bush Hog, etc build a hoe that will fit dozens or even hundreds of tractors.
/ Mahindra backhoe #6
KMW builds the 1500 backhoes. I don't know who makes hoes for the emax tractors, could be TYM, KMW or someone else.
/ Mahindra backhoe #8
Does Bradco still make the larger backhoes? Specifically the backhoe for the 3550?
/ Mahindra backhoe #9
2014 Wacker Neuson ST45 Compact Track Loader Skid Steer (A61567)
2014 Wacker Neuson...
JOHN DEERE CART (A62131)
JOHN DEERE CART...
John Deere 8310R Tractor (A64047)
John Deere 8310R...
2022 BOBCAT E35 R2-SERIES PLATINUM EXCAVATOR (A62129)
2022 BOBCAT E35...
ISUZU CAB OVER REFRIGERATED BOX TRUCK (A62130)
ISUZU CAB OVER...
GOLF CART FRAME & CAMPER/RV WINOWS & SHELL (A62131)
GOLF CART FRAME &...
